stem spacers - abov...
[Closed] stem spacers - above or below?
[#3667542]
thought i'd try and place my spacers above my stem rather than below, to try and see if it helped lowering my ride position slightly.
will i get any issue not having a spacer before the stem and the top headset "bit".
not gone for a ride like t yet to know if it makes much difference.
Posted : 11/02/2012 7:47 pm
not a problem.
Posted : 11/02/2012 7:48 pm
No, the spacers are only there to make the bike fit you properly (as long as you put em in the right place anyway)
Posted : 11/02/2012 7:49 pm
ive had to put a few spacers below my stem because the faceplate was fouling the top headset. its doing that because its a really short stem, 50mm i think.
Posted : 11/02/2012 8:22 pm
Your power output may vary by 80 watts.
Posted : 11/02/2012 8:35 pm
 LsD
You're just trolling, Al...... 😡
It'd be 72.46 watts at the very most.
Posted : 11/02/2012 9:13 pm
depends if it's carbon or alu
Posted : 11/02/2012 9:38 pm
its actually a combination of that and how much your wheels weigh. that is the single most critical thing along with everything else.
Posted : 11/02/2012 9:49 pm
I drilled some alu ones, but the results were negligible.
Posted : 11/02/2012 9:57 pm
