Steerer length?
[Closed] Steerer length?
[#2733465]
The headtube on my medium trance x measures 143mm and my hope stem is 42mm. New forks I'm looking to buy have a steerer of 183 😕
I'm I cutting it too close?
Posted : 09/05/2011 3:54 pm
Yes.
Posted : 09/05/2011 4:12 pm
Don't forget there's a headset to fit in there somewhere...
I'd steer clear (pun intended)
Posted : 09/05/2011 4:16 pm
You could swap to an FSA stem (or similar) with a 35mm stack height but depending on the headset height, i'd steer clear to be safe (unless the fork is local and you can try before you buy).
Posted : 09/05/2011 4:33 pm
Just going through similar.
150mm HT
30mm Headset height (Hope)
40mm Thomson stem
220mm Steerer minimum
Posted : 09/05/2011 4:36 pm
The trance has a integrated or semi headset so basically sits flush, wasn't going to use spacers anyway. Still a no-go?
Posted : 09/05/2011 8:14 pm
Whats the steerer length of your old forks?? Seems tight.
Posted : 09/05/2011 8:15 pm
Well you've got 182mm of steerer and 185mm minimum of stack, not including the HS which will add a couple of mm either side I'd say even if it is flat.
Would well be needing some new forks there
Posted : 09/05/2011 8:18 pm
It's a new frame so haven't had forks on it before.
Posted : 09/05/2011 8:26 pm
