Specialized pitch f...
[Closed] Specialized pitch front mech size ?
[#2325383]
Does anyone know the front mech size for a 2008 specialized pitch all info on specialized's website is for e types. Anyone the size ? Cheers
Posted : 30/12/2010 10:24 pm
think it,s 34.9.
is the seatpost 30.9 if yes then it is. 😉
Posted : 30/12/2010 10:32 pm
its a bolt on one - it fastens to two bolts above the bb so the diameter of the seatpost is irrelevant - if i remember correctly you have to detach the bracket section from the standard derailleur then just screw it on - heres one http://www.chainreactioncycles.com/Models.aspx?ModelID=20686
think if you tried to put a normal one on then it'd foul on the chainstays.
Etype is the size, an etype front mech fits round the bottom bracket, for a pitch you unbolt the bottom bracket fitting plate Off the mech and bolt the mech direct to the swingarm that has two small holes that the mech bolts to.
Posted : 30/12/2010 10:38 pm
I dont want a e type im going for a multi pull so 34.9 it is cheers rob
Posted : 30/12/2010 11:00 pm
Think you will have trouble tbh, the pitch has a very bent seat tube near where you would mount mech
Posted : 30/12/2010 11:52 pm
As does the FSR and stumpy from the same year but they have non e-type front mechs but you will need to keep the seat tube kink in mind when selecting the mech
Posted : 30/12/2010 11:55 pm
Ah.the shortest answers are the best 😉
The guy asked for size not type.
O well if only you lot had read the post properly.hehehehe.
no probs rosss
Posted : 31/12/2010 12:37 am
Give the guy a prize 😉
Posted : 31/12/2010 10:38 am
Madmatt is right it doesn't clamp around the seat tube it bolts onto 2 bolts. I've not had to replace mine yet so wasn't aware you can just take apart a normal front mech. If this is the case then the size is completely irrelevant.
It's quite a busy area around there on a Pitch and I would be very doubtful if a regular mech clamped around the seat tube would work at all - there must be a reason why they went the 2 bolt attachment method. It is very solid and easier to install though. 🙂
Posted : 31/12/2010 10:53 am
A normal one won't work, I've got a pitch and I've tried, the spacing is wrong and the swingarm fouls the mech on compression, so good luck Hahaha 🙄
Posted : 31/12/2010 12:41 pm
no probs rosss
Size isn't the only issue smartass hence the more expansive answers from those in the know...
Posted : 31/12/2010 2:19 pm
Exactly !
The 2008 Pitch the OP refers to takes an E type mech:-
[url= http://www.specialized.com/ca/en/bc/SBCBkModel.jsp?sid=08Pitch&gold_ses= ]2008 Pitch Pto[/url]
Removed from the E mount and bolted to the frame mount.
Posted : 31/12/2010 2:26 pm
Khani your clearly talking from experience so is it impossible to fit a multi pull to it so you deffinatly need a bb mounted e type ?
Posted : 31/12/2010 4:08 pm
Don't even attempt to fit a normal band-on front mech to a Pitch, it's bolt-on (e-Type with the bracket removed, as above) only. Just forget it, it won't work.
Posted : 31/12/2010 4:35 pm
Yep, get an etype and save your sanity, you can get top or bottom pull etype ones if you want to try a top pull cable, you'll need a bolt on cable stop thingy as well though, not worth the bother really as etypes are the same price as normal ones, in fact last time I looked on crc they were cheaper
Posted : 31/12/2010 4:36 pm
OK cheers matey
Posted : 01/01/2011 1:24 pm
