Id settle for that mate! My amps up to 7 out of 10 with squeeze on full
Chat Forum
sonos vs squeezebox
Posted 4 months ago #
Just spoken to logitech, they say it must be faulty so I got to return it to amazon. Thats a shame :-/
Posted 4 months ago # -
You did turn up the volume on the Squeezebox, didn't you?
Yep, on max
I found the same with my Touch last night when I connected it up to my Linn Classik/Linn Kans - I had to increase the volume on the Classik to 70% of max whereas with a CD I wouldn't have it past around 35-40%. The touch was set to ~50%.
My amp is able to vary the gain for each source - can you do that on yours?
Congrats on getting the Squeezebox, commiserations on having to send it back...
My SB Duet does need a bit more volume from the amp to get it to the same level as CDs, but it's only a few notches; I just have the SB at full volume. The volume changes between BBC radio and my music though, which isn't the end of the world.
As for ripping, I'm a cheapskate, and hence a bit surprised at all the paid-for suggestions above. MediaMonkey does everything I need: it's free, will identify CDs, and will happily rip to most formats you might need. For MP3, there's a 2 minute trick to ensuring it always rips even on the free version, but it's great for sorting tags, adding album artwork etc.
sorry to hear about the sound issues on your squeezebox.
Thought i'd just mention that new models of my sony blu ray player have a function i wasnt aware off. Its called party streaming.. and works like this. worth considering for an alternative
I have a squeezebox radio and can very happy with the sound quality, annoyingly it needs the pc on to play radio.
Seen some cheap too recently.
hmm thats slightly annoying, is it really so difficult to pop a DAB, FM, AM tuner in the same box
will it work nicely from my netbook, or am i going to have to leave the PC on upstairs.... full time?
My SB Touch doesn't need the PC on, just a wi-fi connection. No idea about other SB devices though, you just need the SB server software installed to stream music files.
This is the same for my SB receiver that I have plugged into my AV Receiver.
My touch doesn't need pc on for radio...odd...is it a set up option?
It should just pick up the radio signal wirelessly/via ethernet on your router, no ?
Is it connected to your PC in some way ?
Nope, just wifi.
Quick update. Had a play this morning before work, and plugged the rca leads from cd connection on amp to the squeeze. And it was LOUDER!! So, maybe more of an amp issue than squeezebox. Am I ok to use different connections other than aux? Any implications? Or reasons why this should be happening?
Ta
The only one you don't want to use is a 'Phono' input if you have one. The other line inputs should all be the same. Try plugging your CD player into the Aux. Odd that you laptop sounded Ok on the Aux input but not the Touch though?
Sounds like the auxiliary input is guff.
Oddly my squeezebox radio is working without pc on now!
bingo
if someone could just find me one in white for under a ton, that'd be lovely
Google it...saw them for £90 somewhere.
HOTUKDEALS good, I'll look
£111 plus quidco on the deal on this page
http://m.hotukdeals.com/search?action=search&keywords=logitech&action=search
I'll have another play tonight thanks. I'm fairly sure for some reason the manual says not to plug stuff into phono and aux at same time. And maybe no selector for aux, just phono. Not in front of the amp at the mo tho. It's an arcam delta 290 if that means anything to anyone.
Thanks a lotPosted 4 months ago # -
Just a thought but you used the word 'selector'. Is it a rotary one rather than a set of switches? If so it might be that the contacts are dirty and its not selecting the channel properly everytime and it was just a fluke that it decided not to work when you plugged the Touch in. Perhaps try it again with the Touch and move the selector backwards and forwards through the channels to see if it's an intermittant problem.
I vaguely remember having a similar problem where the music was really faint and i had to crank up the volume and it turned out to be the wrong channel and there must have been some sort of crossover in the amp that i was picking up.
Yes you're right, its rotary. And thinking about it, its got history for this
a while ago the speakers kept swapping from one side to the other, and when I tweaked the knob around it'd alter the sound and crackle. Mebbes time for a new amp. It's decent quality tho, so I'm loathe to get rid. Like I say, ill play with the different channels, but if I can get away with using the tuner socket that'll do me for now.Thanks a lot
It might just be a case of soldering a new switch onto the main board, it's worth a Google.
just had another play at switching stuff around. as i was sort of expecting, cd and squeezebox both play decent volume in either of the cd and tuner sockets, but both are quiet in the aux. so..... as i dont have a tuner now, ive reconnected cd to cd, and squeeze to tuner and sounds fine. i remember looking into what may have been the problem with the selector a good couple of years ago now, and thinking it was too complicated to fix myself.
so i think ill carry on like this until a decent amp comes along for sale maybe
now im going to concentrate on ripping some flacs and seeing if i can suss the tagging. nicko74 above suggests he uses media monkey which rips AND identifies cds, so ill look at that. im interested to hear if anyone has a reason why it may be worth pressing on with EAC compared to mediamonkey tho.
thanks a lot
Yup, MM does everything I need - I used to use dbpoweramp for ripping, with the Godfather for tagging, but I upgraded to Windows 7 and dbpoweramp stopped working so I went for an all-in-one solution.
I think MM does most things itunes can, and takes a shedload less in the way of resources, too; it's good for managing tags, and (I had a quick look last night) can rip to ogg, FLAC and wmv beyond the usual range of mp3 options.
great stuff thanks mate, worked a treat. no more ripping to wav, converting to flac just to get an unnamed album. mediamonkey done the lot in a oner
just one niggle im having at the mo. just listening to 6 music on it, and thought id save a few radio stations to favourites for future. yet when i put radio 1 or radio 2 into 'search' then 'internet radio', im getting a server connection error on screen. yet the control panel says server is working, plus im actually listening to the radio anyway!
any ideas on that one?
cheers
My radio does that for some odd reason, on/off seems to sort it
FFS my touch is now telling me it's laying music but giving no output
on off and it works
oh dear. Mine has occasional server dropouts, but is otherwise reliable.
Just bought a NAS so over the next few weeks i'll be ripping my music collection also & dragging myself into 2012!Posted 4 months ago # -
FFS now my remote app is seeing only 1 of my 3 players..
i may be having the same prob, just having a play again trying to connect wifes laptop now.
downloaded server to hers (laptop 2?) and logged in using my details. it found her music in her folders, so i thought id see if squeezebox found it and played it. its still only finding mine on my laptop.any ideas on how i overcome this?
thanks
Reply »
You must log in to post.
