SINGLE SPEED SET-UP...
[Closed] SINGLE SPEED SET-UP ?
[#565431]
Thinking about setting my 'runaround' (on and offroad) to single speed but what's best at the back ? 15, 16 or 18 ? And up front ? 32, 34 ?
Also I'll need a chain device I guess, anything else ? Recommended chain ?
It's for a Cannondale Chase, if that helps. Cheers guys....
Posted : 19/05/2009 6:30 pm
depends where you live really
i started on 32 16
now run 32 18 and use a half link chain
Posted : 19/05/2009 6:47 pm
 jonb
how hilly, how much offroad and how much on road. I do some fairly steep hills on the road and manage 42:16, spin out at in the mid 20's mph.
Off road that's a too big a gear to use although I can manage tow paths.
Posted : 19/05/2009 6:57 pm
 jonb
I'd get a 34 up front and then a 14,16,18 sprocket set from ebay (about a tenner) before deciding which one you like.
Posted : 19/05/2009 7:01 pm
53:11 is a mans gear
Posted : 19/05/2009 7:14 pm
scrap that - THIS is a mans gear:
Posted : 19/05/2009 7:16 pm
qwerty - Member
That's his mountainbike - you should see his road bike 🙂
Posted : 19/05/2009 9:28 pm
Have used - 34:16 (great round herts/thetford forest), 32:16 (bit of a compromise for me), now using 34:18 round Devon (Woodbury mostly) as I've turned into more of a spinner than a stomper.
You'll probably want to tinker with your gears as you go. My first set ups were dictated by chainstay length rather than desired ratio.
Posted : 19/05/2009 9:30 pm
Cheers guys. Good idea jonb about the e-bay bit. I've tried just sticking to one gear on a 'geared' bike but I always end up cheating, so I'm thinking, if I actually bite the bullet and set it up I'll have no choice.
Okay, maybe no knees left.....????
Posted : 20/05/2009 4:50 pm
single speed gearing is a personal thing, some fast guys like shaggy, Phil, and the LaLondes all use around 55 inches( around 34x16 ) but equally fast guys like Buck Keich use 34x18, so its what ever you prefer to push, spin, mash, whatever your legs can handle.....
Posted : 20/05/2009 5:00 pm
32:16 here.
I spin out at 28mph, well I can't go any faster than that. but i only really use it at Cannock,
if your starting i would say 32:17 and work your way up
Posted : 20/05/2009 5:19 pm
