Should I put a coil...
[Closed] Should I put a coil shock on my 5 Spot?
 Crag
[#1520183]
As above, I've had my TNT 5 Spot for about 6 months now and as yet have been pretty much uninspired.
It climbs like a mountain goat but when the trail points downwards it doesn't feel anywhere near as assured as my old Meta 5. I messed round with various air pressures and rebound and can't get it to feel anywhere near as plush and responsive as I'd like.
So, anyone got any experience of putting a coil shock on? Any vast improvements? And is the weight gain noticable on a 30lb trail bike?
Posted : 18/04/2010 6:45 pm
went from a rp23 to coil and its miles better, did'nt notice the weight either,
Posted : 18/04/2010 6:53 pm
PUSH'd VAN R crag, you'll never look back 🙂
Posted : 18/04/2010 7:02 pm
you'll never look back once youve fitted one
Posted : 18/04/2010 7:06 pm
 Crag
Cheers fella's, all positive so far. This is the last throw of the dice before I chop it in for a Lapdog or, dare I say, Orange 5.
Any negatives I should be aware of?
Posted : 18/04/2010 8:02 pm
Orange 5.
Posted : 18/04/2010 8:04 pm
 Crag
yeah, fair enough 🙂
Posted : 18/04/2010 8:05 pm
 duir
radoggair - Member
Orange 5.
Care to elaborate?
Posted : 18/04/2010 8:29 pm
[i]Care to elaborate?[/i]
I was wondering that. Thought it was regularly top rated in it's class.
Posted : 18/04/2010 8:59 pm
Which is a class or 2 below a 5 spot
Posted : 18/04/2010 9:28 pm
radoggair - Member
deary me, there is some utter crap posted on stw and this has to be the ****iest for a while.
The word stroker springs to mind. ( I guess all sports have them)
Posted : 18/04/2010 9:34 pm
When I said class, I meant 5 inch travel trail bike class, so they're kind of in the same group. I haven't ridden either so can't really comment myself. I'd assume the five's a bit like my Alpine.
Posted : 18/04/2010 9:40 pm
Well I took a coil (Romic, on it's last legs) off to put an RP23 on a Horst 5 Spot. Miles better and more controlled, better than the Romic, but took a couple of rides carrying the shock pump until I was happy. I much prefer being able to flick the propedal lever when I want depending on the situation. At the end of the day if it doesn't feel right, give it a go with a coil.
Posted : 18/04/2010 9:48 pm
Hey. How old is the 5 spot and what condition are the bearings in? if you don't mind me asking.
Posted : 18/04/2010 9:49 pm
 Crag
It's a 2008. Do you reckon it could be the bearings rather thanthe shock?
Posted : 18/04/2010 9:54 pm
take the shock off and you will see how the bearings are
and as far as trail bike of the year goes, according to mbr, its the lapdop, closely followed by your "special" brothers metalwork project, the orange 5.
Posted : 18/04/2010 9:56 pm
Hey. Hard to say depends on the manufacturer but turner more likely than not run enduro max, so they last a good while.
I would take the shock off and run the frames rear end gently through it's travel. it only takes 5 mins and you'll feel right away if the bearing need done.
Posted : 18/04/2010 9:57 pm
Binding or siezed bearings will interfere with the shocks dampening and cause instability in the bikes handling especially at speed.
Posted : 18/04/2010 9:58 pm
Turners run on bushings Kaesae, I thought you were supposed to be a mechanic 🙄
Posted : 18/04/2010 10:03 pm
 Crag
I'm pretty convinced new bearings won't help.
Interesting to hear a different perspective in terms of going coil to air. Got to admit, I use the propedal on sustained climbs. Will I miss this or do you kind of get used to not having propedal?
Posted : 18/04/2010 10:07 pm
MTFU
propedal is an oxymoron
its basically for women and hairdressers
and top marks for spotting (see what I did there) that turners don't have bearings. Schoolboy error!
Posted : 18/04/2010 10:38 pm
Put a CCDB on my HL 5 Spot - absolutely superb, the back end just hugs the ground. About 30.5 lbs so not too bad weight wise, obviously a air can would be lighter, but I just prefer the feel of a coil.
Posted : 18/04/2010 10:48 pm
 Crag
Im working on my perms and highlights as we speak.
Ccdb overkill for general trail duties?
Posted : 18/04/2010 10:52 pm
 Crag
Posted : 18/04/2010 10:53 pm
Have been enjoying the Romic that I came with my first 5 Spot back in '02, but it dearly needs a service - any know who might be able to do the business on a Romic T2?
Posted : 18/04/2010 11:15 pm
 drew
Fit a DHX 5 coil and you get propedal and an adjustable boost valve. I fitted one to my push rockered 5 spot prior to a trip to the lakes recently and was very pleased with its performance.
Posted : 18/04/2010 11:25 pm
Elaborate please if you can or will, i mean anyone who's anyone (who can ride properly) knows a 5 spot is a league above an Orange 5
Posted : 19/04/2010 1:01 am
calling rad a stroker and saying some folk talk utter crap on this forum with the orange 5 comment over the 5 spot is a bit harsh.. especially when you look at the number of ex 5 owners that have ridden and switched to a 5 spot (also a certain other horst link 5 inch travel bike that caught the attention of a lot of people over the past 3 or so years)
theres about 4 on this forum that seem relieved to have made the switch and a few others where i used to work that have all said the same. NEVER has there been anyone that went from an orange 5 and been let down.not my words.. just folk that have owned both.
Posted : 19/04/2010 1:16 am
 Soup
The Orange 5 doesn't look right at all. I would try anything first if that's the other option.
Posted : 19/04/2010 1:33 am
Danny Macaskill and Rowan Sorrell seemed to be doing quite well on their Orange Fives coming down the Nan Bield Pass the other day....
Posted : 19/04/2010 9:55 am
Kaesae.. fivespots use bushes in all the suspension pivots not bearings 🙄
Crag...the stiction in Turner bushes is one of the reasons they they feel harsher over fast bumps. After going to a Hustler with bearings in all its rear pivots, the suppleness of the Hustler was in a different league (both bikes were running std. RP3's)
Posted : 19/04/2010 10:04 am
DeanoT. You snookered as far as servicing the Romic is concerned. Stendec use to do mine, but they have run out of parts after Romic went bust. This was the main reason why I binned my Romic at Christmas after 5 years of faithful service.
I have put on an RP23 in its place. Its taken me something like 3 months and 2 emails to Turner to finally get it dialled, but now I have, I have to say that it is in a different league to the Coil. I use Propedal on Tarmac but nothing else, off road climbs are just much easier with the shock hugging the ground. It really has been a revelation and made the bike even better.
Be prepared for a bit of faff getting the shock right and might be worth you speaking to Turner to help you out, but it will be worth it in the long run.
Posted : 19/04/2010 10:18 am
Ed,
Riders that good will be able to make any bike sing. But of course, you know that.
Posted : 19/04/2010 11:12 am
DeanoT....As Lowey said above. When Romic went bust, Dave @ Stendec sold his Romic charging jig (said it cost £1200) before he lost too much on it. I was in the same predicament with my Romic from my old Ellsworth. After talking to dave about what the jig entailed, I set about making one. The problem with the Romic, is getting the little plug back in next to the main shaft seal while pumping 180 psi into the hole. I replaced the 'O' rings from the compresion and rebound adjusters (thats where the original leak occured) filled with fresh fluid, charged and refitted the little plug with the help of my new jig. Worked first time, chuffed.
My ACME Romic charging jig
DeanoT, if your shock is just in need of a few seals and fluid, I may be able to help. I don't claim to be suspension guru. But for the sake of £20-30 (at a guess) I may be able get a bit more life out of the old shock yet 😉
Posted : 19/04/2010 11:22 am
 Crag
So, button pressed and push'd van r on the way from tft.
I'm away at the lakes this weekend so once I've got the rebound dialled I should be able to give it a decent test.
Interesting to hear people coming back to air from the romics and been massively impressed. I'm running a RP23 at the moment and tbh the rear end just feels wooden.
Hopefully coil shock technology has moved on since the days of the Romic otherwise I'll be terribly disappointed. And if this is as good as the 5 spot is ever gonna get than the idea of an Orange might not be as ridiculous as some people suggest.
Posted : 19/04/2010 1:54 pm
don't do it - I have a bag of scaffolding poles, a biscuit tin and a welder here, you can make your own.
I don't mind single pivot (the tr450 is one), but lets have a linkage driven shock at least. Put some effort in for gods sake....
as for Danny and Rowan, I'd ride any old crap if it was free, as well.
Posted : 19/04/2010 2:07 pm
I recently swapped my Romic for a VanR, it performs well but I get a lot of ghost shifts now.
Anyone know if pushing it would cure this?
Posted : 19/04/2010 2:28 pm
I assume you are talking about rear nech shifts - I wouldn't have thought a shock could cause ghost shifts. New cable required perhaps?
Posted : 19/04/2010 2:31 pm
i'll be interested to know how you get on crag and how long it'll take for tftuned to get you the pushed van r, i think their website did note some of the pushed products were out of stock (but that may have recently changed)
got to laugh at some of the shite some people write on these threads though, having owned two TNT turners in the past, I now own two oranges and prefer an orange (especially with a coil fitted) so maybe the haters should elaborate further on how I obviously can't ride properly... go on please..
crag - make sure you come back on with some feedback and piccies 🙂
Posted : 19/04/2010 3:25 pm
 Crag
TFT were as good as expected, ordered this morning followed by an email regarding weight and bike. Got a mail back within the hour saying it would be shipped tomorrow so push kits must be back in stock.
I'll let you know how I get on.
Posted : 19/04/2010 6:37 pm
 Crag
Posted : 19/04/2010 6:47 pm
so good, you said it twice 🙂
Posted : 19/04/2010 7:12 pm
Hey fivespot - that's very good of you! The shock has not been abused so minimal basic service is probably fine. I did replace it with an RP3 back in the day and sold my '02 frame with the RP3 still attached. '06 frame came with a DHX5 which I've never got on with and which Turner realised was not ideal - they went back to the RP23 for '07 I think.
Anyhow - servicing help very much appreciated!
Posted : 19/04/2010 9:49 pm
DeanoT, I Have sent a mail to your "The Ride Journal" link 5 mins ago 😕
Posted : 19/04/2010 9:53 pm
Thanks! Just replied :^)
Posted : 20/04/2010 11:25 pm
