With all the air out of the shock, should you be able to compress it enough to ease the O-ring off the shaft?? IMy RS Debonair plus fitted to a MK2 Nomad doesn’t. It stops short of the end of the shaft by about 3-4mm.
Also seems the air pressure charts are miles out, I know they should be taken with a pinch of salt, but I’ve had to put in an extra 35psi.. It’s all been set up as per the RS video a couple of times and coming to the same result. Maybe there is an issue with the shock (it’s only 2weeks old) which will be a PITA
Carlos
