Shimano hub bearing...
[Closed] Shimano hub bearings, and Halfords.....
 PTR
[#2725629]
I've just been helping to change and grease the bearings in a Shimano rear hub. This involved a trip to Halfords, the only place open at the time, we were sold caged bearings. I've never seen or heard of caged hub bearings before. Is it me or Halfords? They do seem to be working.
Posted : 06/05/2011 9:47 pm
How did you get them in?
Posted : 06/05/2011 10:10 pm
 PTR
Beats me, good luck I suppose. First thoughts were along the lines of "bloody Halfords muppets", but I've been using hope hubs myself for 15 years, so took the chance that Halfords may have known what they were doing.
Posted : 06/05/2011 10:12 pm
I guess if they work then hang in there but I'd expect the caqge to disintergrate after a while. You could always remove the bearings from the cage and use them loose. You'd need a couple more to take up the space the cage used though (does that make sense?)
Posted : 06/05/2011 10:25 pm
Usually found on cheap and nasty hubs, used for quick assembly in the factory, and usually only spread the load over 5 or 6 balls instead of the usual 9 in a rear hub. I'd replace them with loose balls as soon as you get the opportunity.
Posted : 07/05/2011 7:58 am
 Bez
Cages do two things. They make it easy to fit and remove the balls, and they reduce the number if balls that will fit in the bearing.
So they'll roll fine, but since hubs carry significant load, the lack of balls means a greater wear rate. When it's convenient, take them out and fit a fresh batch of loose balls.
Posted : 07/05/2011 8:36 am
IME shimano hubs use 9 loose bearings (each side) sandwiched between the cup'n'cones directly... no cage. I'd check the service manual for your hubs but suspect you'll need different bearings.
Posted : 07/05/2011 9:27 am
I'd agree with changing back to loose bearings when possible, and check the size that you fit, they're all 1/inch and what seems near enough probably won't be. A decent LBS should be able to order up what you need or even have them in stock. Choose a good grease and pack it in well, then take your time in tightening the cones and locknuts, that has always been the bearing killer for me.
Posted : 07/05/2011 10:33 am
I got my bearing from this ebay seller:
http://myworld.ebay.co.uk/ladyofletters_123
You will have enough to last for years just make sure you do them before the cup and cone receive damage
You need 3/16" bearings for front shimano hubs and 1/4" bearing for rear shimano hubs
Posted : 07/05/2011 10:43 am
