If your happy go for one just experience says don’t touch a dropper in the first year/gen unless you want to test the warranty.
Apart from the your/ you’re who’s/ whoes fiasco above ( 😉 ).
I think the reason why most people (including myself) are so excited about this mikew, is that we want to believe that, after several years of companies releasing failed first attempts, this dropper from the BIG S could finally be The One. I’m willing to hold out hope, but probably not cash, cos I’m a s/h only pauper-person.
I want to believe the Big S will have finally cracked this apparently monumental engineering problem. A non-rotational uppydowny shaft fitted inside a tube. It’s not exactly rocket science really, is it?
C’mon Shimano! 😀
Just disappointed it’s not hydro actuated, cos as someone who’s lusted after hydro-actuated derailleurs since Mavic in 1993, that’s what makes the Reverb satisfyingly quite pimpy, if a bit of a faff to set up. There also apparently seems to be some engineering sense to hydro-actuation too, as the hydro button allows for less lever throw, or som’ink, which is cool.. 8)
With Shimano entering the market pricing could get quite competitive too, once this cascades down to Deore-level – then we will have fully pre-programmable GPS position-sensitive electronic auto-drop at XTR level!!!! MMMmmmmmmm…
