Just changed oil, cleaned and lubed one set of Rebas, after putting it together it all works fine.
So I thought, I’ll have a go at the other broken two I’ve got. I had two faulty ones I wanted to make into one working set. One has worn uppers, other has borked damping. Swapping stuff over was easy, old oil was drained, foam rings soaked in fresh oil, etc etc, oil levels were the same as on my old one and same as in RS manual, 15ml to both lowers and 110ml to the damping side upper. It holds air fine, rebound adjustment works as it should but the lockout doesn’t work. I checked on google and it suggested oil level might be too low. Gave that a check and it’s 110-115ml as per the manual but still no lockout.
Any suggestions on what I’m doing wrong or how to get it to work? Could that be some seals in the MC damping unit or something else?
