Seat mounted water ...
[Closed] Seat mounted water bottle cages.......
[#3741765]
We're doing a supported multi-day mtb marathon event this summer, would like to if possible ride without a pack on my back. Dont think I need to carry a huge amount of water as there are regular feedstations but my bike only has one mount, on the down tube.
Anyone ever used any of those seat-post mounted racks on a mtb? Any reason they wouldnt fit? Couple of bottles on there might be enough, I can use the other one for tubes, tools etc.
Posted : 05/03/2012 12:24 pm
No reason it wouldn't work. Topeak also do a bar-mounted bottle cage clamp.
http://www.topeak.com/products/Bottle-Cages/cagemount?WYSESSID=ohrta68h4grpghqp8hsgb6ua17
Posted : 05/03/2012 12:25 pm
I tried it once, you need to make sure if you go down hill you can lean back enough without hitting the waterbottle
Posted : 05/03/2012 12:48 pm
 MSP
Not sure how they would work out, they seem to be intended for road use, may not be so good being rattled around on a mountain bike.
Have you considered a bumbag type hydration pack, should prove to be a lot less sweaty than a backpack in summer.
http://www.camelbak.com/Sports-Recreation/Packs/2012-FlashFlo-LR.aspx
Posted : 05/03/2012 12:54 pm
I had a Topeak one, worked just fine. I remember seeing someone with a double bottle holder on a similar mount, but I'm not sure who made that.
EDIT: This was mainly on 5 hour TQs, so no real need to get off the back or anything too extreme, but it never felt wobbly.
Posted : 05/03/2012 1:06 pm
I bought one of those really small camelpacks for night rides, holds about 1.5ltrs of water, tool, CO2, a couple of tubes, space blanket and helmet light battery. Waterproof can go under the bungee if nececary. It's barely noticable, although I'm guilty of slowly adding everything+kitchen sink to my backpack so bought this one to limit that,
It also leaves jersey pockets accessible to be filled with gells, snacks etc.
Posted : 05/03/2012 1:07 pm
Only problem is the amount of spray from your rear wheel that will cover bottle. If you going that route get bottle with a cap so you not sucking on mud other wise wear a top with back pockets or a small camelbak.
Posted : 05/03/2012 1:12 pm
Where will you keep spares if not in a camelbak or saddle bag? Not sure I'd want everything stuffed in jersey pockets for point-to-point marathon rides.
Posted : 05/03/2012 1:22 pm
I have two, both by Profile designs. One attaches to the seat post, so you cant alter the height, one attaches to the saddle rails.
I dont use either anymore and was going to sell them, can send you pics if you are interested.
Posted : 05/03/2012 1:37 pm
FuzzyWuzzy - Member
Under seat pouch?
Posted : 05/03/2012 1:57 pm
This is why I ask this stuff on STW.
In the Pyrenees, dont think its going to be a massively techical route but yes might want to get my backside over the back on the fast descents, and yes could get filthy back there. That hip-pack looks like it might suit, good idea.
Posted : 05/03/2012 2:31 pm
 kcal
or frame mounted bag - Revelate Designs or similar - use one all the time to keep the bulky, heavy stuff (tube, pump, tools) leaving bottle cage for water, and a small backpack for food, maps and stuff.
[url= http://www.revelatedesigns.com/ ]Revelate Designs[/url]
Something like the Tangle, for example, is just great at swallowing the bulky heavy stuff.
Posted : 05/03/2012 2:33 pm
Check out Decathlon for a 'rubber' mount for bottle cages.
Price was approx £4 and it used 2x re-usable straps to fix to the seatpost or frame tubes.
+1 for the comment about a top cap over the bottle mouthpiece to keep the muck out....a friend got bad stomach upsets doing Transalp a few years ago because of cow/other mess on his bottles.
paulD
Posted : 05/03/2012 2:37 pm
Topeak also do a bar-mounted bottle cage clamp]
That should come with chequered bottles with straws.
The wingnut is also a good option if you don't like conventional packs.
Posted : 05/03/2012 4:32 pm
Selle Italia Optima Technoligika
You know you want one...
Posted : 05/03/2012 4:45 pm
I was just a little bit sick in my mouth
Posted : 05/03/2012 6:06 pm
