SD Card Recovery
[Closed] SD Card Recovery
[#3198475]
I have a 4Gb SD card that failed in the camera and has some precious shots on it. I believe the controller is dead as nothing will see the card at all.
Has anyone used a specialist recovery company for SD cards..any recommendations?
Posted : 30/09/2011 10:38 am
DIY approach first:
Flick the write-protect switch on the card.
Try it in a number of different card readers - some cope better than others.
Check if the card manufacturer has recovery software on their website.
If not then get hold of [url= http://www.lc-tech.co.uk/software/rprodetail.html ]SanDisk RescuePro[/url] and see if that helps (note: they give away licenses for this with some SanDisk cards)
Posted : 30/09/2011 11:00 am
PhotoRec is another good one. when you say nothing will see it? Does windows/ or your OS ask you to format it when you put it in? Does it show up in Disc Manager?
Posted : 30/09/2011 11:03 am
Thanks both but I've tried the card in Windows/MAC 2x different cameras and it is never picked up at all. I think the card controller has completely died.
Posted : 30/09/2011 11:48 am
Any luck in Linux? You might be able to dd the image into something recoverable...
Try Clonezilla / Norton Ghost 2003...
Posted : 30/09/2011 12:26 pm
Have you got access to different (USB) card readers?
Some have more luck than others with bad cards.
Posted : 30/09/2011 12:27 pm
Have a punt with [url= http://www.piriform.com/recuva ]Recuva[/url]. Awful name, good product.
Posted : 30/09/2011 3:11 pm
