FC-M815-1 is for single rings. I’ve looked at pictures on the net, but not found anything conclusive. It has 4 holes in about the right position to fit a granny ring, but I can’t tell if they’re threaded or not, does anyone know?
It could be that FC-M815-2 just comes with the second chain ring, but the crank spiders are identical.
I’m asking because I have an inner-bashguard plate thing that I will use with these, but it’s drilled to either mount to the granny ring holes or to use the same bolts as the outer bashguard and single chainring.
I could do with knowing if I need some longer chainring bolts to accomodate and also, if I do, how long do those bolts need to be?
Cheers.
