Taking my '09 Rev U-turns apart for their regular wiper check yesterday and I noticed the damper rod was really sticky moving through it's travel (and oil was leaking out the floodgate dial but that's another, well documented problem 🙂 ).
I've stripped the leg down (surprisingly easy!), checked the O-rings and all seems fine but when re-assembled it's still really sticky to move.
Anyone know if this is normal? Could it be the o-rings are knackered, even though they look smooth & in good nick?
Also, I've only got 7.5, 10 and 15wt oil. Will my bike spontaneously combust if I fill the damper leg with 7.5 rather than the recommended 5wt (I'm 90kg and do find the forks dive a bit anyway so it may even help???)
Any comments appreciated.
