I'm busy finishing off a cheap-ish build-up on an inbred frame and need to replace the 160mm Shimano rotor and pads on a set of Shimano M575 hydraulic brakes.
Things I don't know….
– Can I use any manufacturers rotors as long as they are 160mm and which would people recommend?
– Which pads are the best replacement option?
I am trying to keep the budget low but would still like a rotor that looks good, i.e. wavy disc. Also, pad wise, this bike is being loaded up as a tourer so I need pads that are up to the job.
Thanks Guys
