Rotor bolts
[Closed] Rotor bolts
[#2507757]
Anti-seize or not? Will threadlock stop them sticking?
Andy
Posted : 25/02/2011 10:36 pm
threadlock - will stop them coming undone and help prevent seizing due to corrosion and more importantly mean you don't have to do them up stupidly tight - so don't be tempted to 🙂
Posted : 25/02/2011 10:52 pm
You would think threadlock was the way to go but some of the alloy torx bolts that are used are not up to it
Like alloy spoke nipples on light roady wheels the fraction of a gramme that is saved is not worth the aggravation when they round off 🙁
Posted : 26/02/2011 12:15 am
Rounded two of mine off last week, drilled heads off and then remembered I used threadlock, couldnt shift them - going to have to go to frame builders place tommorrow for some precision drilling out. Dont think ill be using threadlock on them again...
Posted : 26/02/2011 12:30 am
Cant say I've ever used threadlock on rotor bolts, & cant say I've ever had any come loose either.
Posted : 26/02/2011 12:36 am
It seemed a good idea at the time. 🙄
Posted : 26/02/2011 12:41 am
Winterfold - you shouldnt be using aluminium bolts on discs IMO. Save them for shifter clamps etc.
Most rotor bolts come with threadlock already on (shimano anyway). All you need is a tiny dab of the blue medium stuff (i get the prit-stick style thing from halfords for £6.99).
You then just need to nip them up and you shouldnt have any problem undoing them, especially if you use decent steel machine screws and decent tools not some 99p multi-tool with rounded allen keys.
Posted : 26/02/2011 1:32 am
"GREASE is the word".
Posted : 26/02/2011 6:50 am
Ti bolts and grease for me, no problems.
Posted : 26/02/2011 9:00 am
 OCB
Decent stainless bolts and grease for me, plus a quick check every so often.
Posted : 26/02/2011 9:44 am
Any old bolts here, never check them, never struggle to get them out.
Posted : 26/02/2011 11:01 am
Shimano triangular T25 bolts and the aluminium bridge-washers properly folded over a flat on the bolt is elegant and secure.
I use copper grease on the bolts and have never had a problem.
Years ago I tried stainless steel Allen bolts and loctite....yet another invention for the 'Easy-Out' kit.
Posted : 26/02/2011 11:58 am
what al said - use ccopper grease as you should on all parts that dont move to mak esur eyou can get them off [headcups , BB ups et] but allen key ones are much more likely to strip than torx head ones IME
Posted : 26/02/2011 12:04 pm
Going on the amount of people that seem to have problems then I change my mind - use grease/anti seize. I have never had a problem with threadlock myself but I am used to working on cars so i am used to stuck stuff.
If anyone has problems with them undoing you could maybe put a dab of anti-seize on the thread but then put a bit of anti-seize near the head which will keep out moisture which I am guessing is a big cause of a lot of problems as it will get in between the disc and the hub and the disc and the bolt head. Lots of forces and vibrations going on so probably easy to get moisture in there.
Posted : 26/02/2011 12:31 pm
