Viewing 7 posts - 1 through 7 (of 7 total)
  • Rotor bolts
  • djc1245
    Hi all.
    Has anyone used a Dremel to drill out a rounded off rotor bolt? I’ve got a drill but i don’t think i’ve got a small enough bit, any idea what size i would need? Was thinking 2 or 3mm.
    Dave
    burnsybhoy
    Use a hacksaw to make a groove across the top of the rounded rotor bolt, then use a screwdriver to remove.
    djc1245
    I will give that a try.
    Thanks
    johnners
    You’re better off filing a bit of a flat onto 2 sides then using a pair of molegrips/stilsons with the teeth in good nick. IME.
    uplink
    If they are hex heads you can usually tap in a slightly larger Torx bit & get enough purchase to slacken them
    Worth trying before you resort to cutting tools
    rich-6
    i used an angle grinder 😳
    Whatsit
    There’s only one way to do it proper like.
The topic ‘Rotor bolts’ is closed to new replies.
