Rockshox Pikes diff...
[Closed] Rockshox Pikes differences
[#3947188]
Looking at buying some Pikes but not sure which ones are lightest and what the numbers represents.
Any ideas?
Thanks
Posted : 06/05/2012 3:27 pm
 GW
454 air are lightest, alloy steerer and air sprung.
still not v.light tho
Posted : 06/05/2012 3:30 pm
Higher the number, better they are
Posted : 06/05/2012 3:39 pm
The lightest Pikes are Revelations 😀
Pikes have been replaced by the newer 20mm axle Revs.
I have a dual air 454 Pike, great fork but I'm not sure if the U-turn is worth the weight. I use it so rarely as it takes a lot of winding to drop height, but it does make a difference climbing with a lower front end. Similarly I tried a number of differences between the - and + air chambers but even pressure seems best for me, so solo air may be perfectly fine too.
Coils are alledgedly smoother but come with a weight penalty.
Posted : 06/05/2012 3:49 pm
327 are the cheapy ones that came on some specialized pitch.. no compression control, just a blank top cap. mine do have an alloy steerer though and weigh about 2.2kg
Posted : 06/05/2012 3:54 pm
If lightest is your concern, are you sure you want Pikes? They're not a lightest sort of fork. Strong, yep.
The current Revelations aren't as strong or as stiff but I doubt that will make any difference to most Pike owners. OTOH, they're mostly better damped. And they are a fair bit lighter.
Posted : 06/05/2012 3:58 pm
I will be Looking for some forks for a 456 for winter. Just thinking Pikes for a sub £150 fork.
Wind down to 120/130 and forget.
Posted : 06/05/2012 4:41 pm
The numbers vary and can be confusing...a 409 has a steel steerer, coil spring and internal floodgate adjust, a 426 can either be coil sprung or air sprung with external floodgate and a steel steerer tube and a 454 can either be coil or air but usually has an alloy steerer tube.
I love Pikes. They're easy to work on, stiffer than anything this side of Lyriks and are ultra-reliable. The dampers can be upgraded from a plethora of kits too. I've a set of '10 bolt through Revelations which are very light in comparison but aren't anywhere near as stiff.
Posted : 06/05/2012 5:13 pm
I have a 454 u-turn Air and it seems light enough, don't think I'd want much lighter for the kind of riding they're made for.
Posted : 06/05/2012 5:17 pm
I have Pike 351's which have a steel steerer and compression dampening. I like them a lot. Maybe they are heavy but they feel stiff and strong which is just what I need.
Posted : 06/05/2012 5:33 pm
Original teams are the bestest.
Posted : 06/05/2012 6:12 pm
_tom_ - Member
36s or Devilles not strong enough for you? 🙂
Posted : 06/05/2012 6:39 pm
36's, Devilles SUB £159? I think not ..
Posted : 06/05/2012 6:46 pm
Never said they were 😕
Posted : 06/05/2012 7:11 pm
My 409 coils weighed a tonne but ..I like my 454 coils. Much lighter. The difference an alloy steerer makes over a steel one.
Posted : 06/05/2012 9:03 pm
"Pikes have been replaced by the newer 20mm axle Revs"
Well, the air ones were. The coil pikes carried on for a bit, until being dropped,
I think the lowers (and steerer/crown?) carrying on to the Argyle solo air 140mm
There were a few others that would appear to use at least pike 20mm lowers, they being 2009 Revelation Dual-Air and Dual-Air U-turn (110-140mm) and a few OE Recon 140mm 20mm's from at least Felt and Commencal hardtails
Posted : 06/05/2012 9:26 pm
Thread hijack! I've got a pair of air 426 U-turns that came off my Wolf Ridge, white lowers off an Argyle, been PUSHed by TF, steel steerer, working lovely, few cosmetic marks (not to stanchions) - what are they worth?
Posted : 06/05/2012 9:33 pm
Pound?
Posted : 06/05/2012 9:39 pm
Throw in a couple of jelly babies that have been in your pocket for a week or two and you have a deal my friend
Posted : 06/05/2012 9:45 pm
