A friend bought one of THESE online a couple of months ago and I’m trying to sort out the gears for her.
For a start the chain is rubbing on the inside of the cage on front mech. Without the cable connected and when unscrewing the low screw, the mech catches the seat tube before allowing enough clearance from the chain so it rubs. Mech looks inline to the chainrings. I was thinking that the bottom bracket is too short in the spindle?
Also the front shifter has 3 settings for a triple, as bike is fitted with a double chainset should the bigger ring be used with the middle or outer click on the shifter?
Hope that makes sense….not used to these darkside bike thingies…..
TIA
