Riser bars on a 29e...
[Closed] Riser bars on a 29er?
[#3706780]
Is that a no-no?
Noticed that most 29ers have flat bars
Posted : 23/02/2012 12:37 pm
 ton
i always run risers on mine.
Posted : 23/02/2012 12:38 pm
Mostly 29ers have high front ends so a riser bar wouldn't be needed for a lot of people, no reason not to fit one if needed though (excepting the old spacers/stem angle vs risers argument)
Posted : 23/02/2012 12:39 pm
Hey Ton, what bars did you settle on that suited your wrists?
 scud
I have 10mm rise 711 mm wide Easton Haven carbon bars on mine, which i really like
Posted : 23/02/2012 12:42 pm
i have exactly the same on my paradox , tried niner flat tops first and it did'nt feel right , it's a personal fit/feel thing .
Posted : 23/02/2012 12:48 pm
I currently have risers on mine - but that's just because they were on the bike which I sold to provide the parts. I've considered flats but just seeing how I get on with these first.
Posted : 23/02/2012 12:50 pm
 bol
I've got Easton Haven low risers on my FS and EC70 wide flat bars on my hardtail. It's all about getting the position right, and enough weight over the front, and flat bars on a bike I will occasionally race seemed to make sense. I think Risers look better though.
Posted : 23/02/2012 12:57 pm
 mos
2" azonics on my 21" scandal, but thats probably because On One head tubes are so short.
Posted : 23/02/2012 12:59 pm
Sunline V1 flat bar, simply cos they're cheap on CRC at the mo' and I wanted to keep the front end lowish: 18" scandal, I'm 6'1 and the seat is barely higher than the bars at that.
Posted : 23/02/2012 1:11 pm
Just depends. My 29er has flat bars, a negative rise stem and as short a headset as possible because that's the only way to get the bars to the right height for me with the head tube length and length of forks I have.
Posted : 23/02/2012 1:13 pm
[url= http://singletrackworld.com/forum/topic/everyone-loves-an-ebay-shocker ]Link[/url]
Check that for an interesting 29er riser bar set up
Posted : 23/02/2012 1:17 pm
Risers on both of mine. Flatter bars are more evident as front ends get higher (bigger wheels, more suspension etc) and people don't want to ride choppers. If that isn't a problem, ride what is good for you.
Posted : 23/02/2012 1:18 pm
Risers on most of mine, Nukeproof low rise on 2 (cut to 740mm), Sunline V1 745mm on another and my very little used Inbred SS has Nukeproof flat bars (but a fair few spacers under the stem).
My saddle if almost certainly higher than most riders though so risers are a good option for me as the bars are still always lower than the seat. Shorter riders may prefer flat bars to keep the front end lower (Clubber excepted) but as with anything like this, there's no accounting for personal choice.
One thing i do hate about flat bars is the pain of turning them upside down for trailside maintenance etc, risers provide a nice stable platform and you don't scuff your stem or brake/shift levers.
Posted : 23/02/2012 1:20 pm
 ton
Clobber, i got a pair of Answer pro taper carbon things.
seem to fit my deformed wrists ok so far.
Posted : 23/02/2012 1:32 pm
How regularly do you have to do trailside maintenance for that to be an issue! 🙂
Posted : 23/02/2012 1:35 pm
Well with punctures more often than i'd like.....
Plus just putting the wheel in etc when getting the bike in and out of the car is made far easier with risers. My SS always wobbled over.
1st world problems and all that 😉
Posted : 23/02/2012 2:04 pm
I have Easton Havoc carbon lo riser but I'd like a 750-760mm carbon flat bar. Can't find one ;-(
740mm widest I've found. 3T. I know their are alloy ones....
Posted : 23/02/2012 2:29 pm
I used Easton carbon low risers, & they were fine, but now have some 711mm Niner flat tops & they are abut as perfect a bar set-up as I've ever had. I bought some Sunline 762mm's but they just felt daft. Fancy some carbon Niner Flat-Tops but the £150 price tag is a bit OTT. 😯
Posted : 23/02/2012 4:48 pm
Easton Haven lo rise on one.
Funn low rise on the other.
Posted : 23/02/2012 4:52 pm
