Rigid forks - help ...
[Closed] Rigid forks - help needed
[#676368]
I'm building up a commuter bike and I need some 26" rigid forks. I want to stay away from carbon so I'm looking for cro-mo or alu forks, disk only, and as light as possible.
I had thought of Kona Project 2's which sound ideal but I can't find any disc only ones. Help would be appreciated! What alternatives are there?
Posted : 01/07/2009 1:30 pm
Salsa do some
Posted : 01/07/2009 1:44 pm
Bontrager do an alloy version of their Switchblade(?) fork.
Posted : 01/07/2009 1:50 pm
 D0NK
a quick google shows evans and sunset have canti and rim brake version and if you really cant live with brake posts file them off - better to keep them on in case tho.
Posted : 01/07/2009 2:48 pm
Orange make a nice rigid chromo fork - disc only.
http://www.orangebikes.co.uk/components/
Posted : 01/07/2009 2:50 pm
u mean canti and [u]disc[/u] D0NK
i love my p2s
dey r da bomb
Posted : 01/07/2009 2:55 pm
Even "sus corrected" rigid forks can steepen a bike up pretty drastically. If you want to keep suspension-y geometry have a look at 29er forks, Salsa and Surly are two off the top of my head.
Posted : 01/07/2009 2:57 pm
Strange, I ordered some Kona P2 forks disc only and had to wait 3 weeks till they shipped some in.
Call your LBS and get them to ring the distrubutor in Bristol for stock.
Also check your forks-my first one came with badly/twisted forged drop outs.
They are skinny and look funny on my commuter with huge ali tubes. Will look nice on a small steel tubed frame.
Also lightly grease your steerer against corrosion.
Even Evans cycles have these forks.
Posted : 01/07/2009 3:27 pm
i wouldn't worry too much about the angles - quicker steering is good in traffic jams anyway!
Posted : 01/07/2009 3:30 pm
29er fork will have the wrong offset so you will end up with far too much trail
Posted : 01/07/2009 3:34 pm
Wish I'd seen that Orange fork before I ordered the Salsa one. Looks way nicer.
Posted : 01/07/2009 3:44 pm
TJ, I would guess that some 29er forks are more corrected for this than others, I've been told older ones like Karate Monkeys work OK with a 26" frame.
Vicious Cycles have a new UK distributor so their steel forks should be easily available. No idea on price but they'll be spendy.
Posted : 01/07/2009 3:46 pm
If you dont need suspension corrected (395mm a-c) then these are lovely...
[url= http://www.tartybikes.co.uk/images/forks/large_pashfkdiscblk.jp g" target="_blank">http://www.tartybikes.co.uk/images/forks/large_pashfkdiscblk.jp g"/> [/img][/url]
Posted : 01/07/2009 3:48 pm
Salsa ones are ordered, thanks for the tip
Posted : 01/07/2009 4:13 pm
isn't that orange one a funny length or something? i was thinking about getting one recently and there was something about it that meant it wouldn't have worked (or i thought so).
Posted : 01/07/2009 4:30 pm
What's with the brake mount on the wrong side and sticking out the front?
Posted : 01/07/2009 4:34 pm
These are almost disc-specific and very tempting:
http://www.all-about-the-home.co.uk/onza-tuf-guy-matt-black-forks---2-sizes-561-p.asp
Posted : 01/07/2009 5:18 pm
glenp - Member
Doing that eliminates the "qr / disc / wheel ejection thing" As the braking force pushes the wheel into the dropout rather than pulling it out Existing callipers can still be used
Posted : 01/07/2009 5:34 pm
I have the Orange and the Salsa ones, on different bikes. Can't go wrong with either IMO, both look better than the newer P2s with that 'extender' piece above the crown.
theflatboy - the Orange is 450mm axle to crown so works well on a frame designed for a 100mm sus fork.
Posted : 01/07/2009 7:05 pm
Any particular reason why you're avoiding carbon btw?
Posted : 01/07/2009 9:00 pm
druidh - Member
As they are going on a commuter bike that might get bashed about a bit in teh bike shed etc I thought cro-mo forks might be a bit less fragile, that's the only reason for avoiding carbon really.
Posted : 01/07/2009 9:53 pm
Ah - cool. I've been using some Pace carbons on my commuter and they do take the sting out of the potholes etc.
Posted : 01/07/2009 9:58 pm
Tout terrian do a high quality disc only rigid fork for about £100 (see bikefix.co.uk)specifically designed for touring/commuter use
Posted : 01/07/2009 10:17 pm
