Either:
Too much oil in the upper damper side leg. (unlikely if they were getting full travel until and haven't been touched recently.
or
the spacer that separates the upper and lower leg oil chambers seal/s have gone allowing oil into the lowers.
The bottom out bumpers being out of place is unlikely unles the forks have been apart.
A service with seal change will sort the problem or you could just pop the lower off and just replace the seals on the spacer and oil in the lowers, however it would be worth checking levels in the damper leg as the amount lost may affect it.
I have separate or complete seal kits to rectify this fault.
