Replacing window wi...
[Closed] Replacing window with french door
[#3987072]
We've currently got a window in our kitchen and in order to allow more light we'd like make it into a french door. Is this as simple as I think it is or are there some hidden issues? (it's a standard brick and block cavity wall below the window). Thanks.
Posted : 18/05/2012 10:59 am
Will the door be the same width as the window thats there just now?
Posted : 18/05/2012 11:05 am
 wors
i did the same in my last house.
Window out, cut down with stil saw, bash the old brick out. Put french doors in
Cover the cavity while you work, trying to retieve a hammer from one isn't easy!
Yes, window opening is 1190mm wide, which appears to be a standard size 🙂
Posted : 18/05/2012 11:07 am
check local building regs and also think about what happens if you breach the damp proof course but I don't think there's any structural work needed to reinforce above the new door.
Posted : 18/05/2012 11:10 am
Sufficient height under the lintel ? Water ingress via the threshold ? .......are you having a step up ?
Posted : 18/05/2012 11:12 am
As long as the top of the window is high enough to be used as a doorway 🙂
Obviously you need to check things like plumbing that may be behind any kitchen units currently there, whether steps will be required outside etc. Also, in our situation it was a close thing with the new door hitting the gutter on our extension (which is a step down so the gutter is low.
Posted : 18/05/2012 11:13 am
Hey - we want to replace a french door with a window. Want to swap? 🙂
Posted : 18/05/2012 11:14 am
We've currently go the back door approx 400mm and then the window, unfortunately they have two separate lintels. The top of the door and window are level and I'd take the window down to the same level as the door (directly above DPM). The inside wall is clear.
Initially we were looking to put a small extension onto the kitchen, but the quotes are far too high to make it worthwhile, so I'm just looking for a cheap(er) option to get more light in and allow us to see the garden (existing window sill is quite high). Thanks.
Posted : 18/05/2012 11:20 am
In theory a french window/door should open inward, although it is unusual for glazed rear doors to open internally in the UK as it restricts available space for furniture.
Although personally I don't like outward opening external doors as is it causes problems with the wind catching them (restrictors can be fitted but they have to be very securely fixed) And end grain can be exposed to the elements (fit drip/canopy above door) Also the hinges are prone to corrosion.
Posted : 18/05/2012 11:33 am
did this last year on mine, fairly easy job
window out
stil saw out down to required level
tidy up edges
fit new doors
easy
only thing you really have to watch is internal / external levels you may need a step on the outside as your finished internal floor will be higher than outside
also as you are altering the external apperance of the house you will have to submit for a building warrant and pay the required fee
Posted : 18/05/2012 12:02 pm
If you are using a window company, they will be fensa registered which does away with YOU having to mess about with regs.
I think we used to charged about £850 to supply & fit French doors and make opening using original lintel. That was a few years ago so may have gone up but should be under £1k
Posted : 18/05/2012 12:18 pm
We had this done last year. The door was installed just above the DPC with a step on the outside. The door is the same width as the window so the existing lintel was fine.
We fitted sturdy metal stays and a door stop to stop the doors swinging in the wind and causing damage.
Posted : 18/05/2012 12:27 pm
We were about to do the same when the bricklayer pointed out that the outer wall had no lintel and although that wasn't a major problem he advised that if we were doing the work to stay long term rather than sell then he'd put a lintel in. Anyway the upshot of it was that as we decided to get the lintel done we decided also go from a 6' opening to an 8' one. It meant getting a structural engineer in and going through building regs but the end result is vastly better than what we would have had and well worth the extra cost involved.
Posted : 18/05/2012 1:10 pm
