Send wife away for the weekend then rip through with the steamer??**
Whatever you do – don't even contemplate full removal of the offending item until you have scrapped all the wood chips off…. PITA, and it does feel like 'doing the job twice' but it leaves lots of 'openings' then for warm water / steam to penetrate and do it's job – makes it much easier in the end 😀
**This is in lieu of a large donation to The Bank of Brownie Points*
*If Bank of Brownie Points has been shut down due to the economic slump you may at least be avoiding a large deposit arriving at The Bank of Earache!! 😉
Or – go for Brownie Points Blowout – send her away and get trusted friends to give you a hand to turn the room right around for her return – in a Changing Rooms styleee? ?
EDIT – beaten to it with 'scrape chips off first' advice – sorry..
