Viewing 5 posts - 1 through 5 (of 5 total)
  • removing ss freewheel
  • cycleofaddiction
    ive got a 20 tooth dicta freewheel with no notches for fitting a tool is there a way of removing it without a trip to a bike shop or destroying it ?
    thomthumb
    no little slots for the tool?
    tony_m
    Old thread here might help! I used the dismantle / grip in vice / turn wheel method to get the original Dicta off my Inbred, and then replaced it with an ACS which has slots so you can use a proper tool as above!
    HTH
    Del
    destroy, discard, replace.
    mattsccm
    There is something on a Dicta freewheel that you can grip, I have removed several.
    If it looks like the pic (probably not going b what you say ) then use a tool or as I did a bit of 1/4″ bar cut to fit in and held in a vice. I have also used a couple of large old fashioned head set spanners held in the viceto allow the freewheels to be gripped.
    Just checked , mine are all as shown. So try the bit of flat bars trick.
    Useless bits of junk , they don’t last in mud but are cheap so handy to experiment with.I use Shimano DX which are still only sub 20 quid.
The topic ‘removing ss freewheel’ is closed to new replies.
