Hi,
I have a bit of a problem - I want to bin these cheap ISIS cranks that came with my Genesis IO but using a crank puller on the drive side stripped the thread. I got the non-drive side crank off though. Can I disassemble the bottom bracket like this? What tool would I need for the 8-notched ring on each side?
[img]
[img]
Cheers,
Andy
You'd need one of [url=
[/url]tools to remove the ISIS BB.
[IMG]
However, unless you can get the drive-side crank off, there's no way of getting the BB out.
For further advice I defer to other, more betterer members of the forum......
You may be lucky, if you find a C-spanner for an old style BB lockring you should be able to loosen the collar, but getting the remaining cup out may not be so easy.A 2 or 3 legged puller, and some ingenuity in getting it to fit/work, may be your next hope.
whats wrong with using crank bolt extractor caps?
on and on - Memberwhats wrong with using crank bolt extractor caps?
His thread is stripped.
Thwack the crank arm wit hammer whilst using a big lever? Failing that cut the crank arm off.
I'm assuming the chain-set is going in the scrap bin?
Method 1:
Get some heat on it! A long punch and batter it off from the non drive side.
Method 2:
Heat! Get the chain ring off and use a 2/3 legged puller. These are cheap enough:
That one will give you the option of 2 or 3 legs.
Marko
you misunderstood.
why wasn't an extractor cap used initially ,as opposed to a crank puller.
the thread would need to be pretty darn ****ed to not be useful in getting the arm off.
I had exactly the same thing happen to my IO cranks. I used a three legged puller and lots of heat. If not cut/chisel it off.
Take the bolts and and ride around the block. Put loads of pressure through it though
Many thanks for all your suggestions!
Since I don't have the 8-notch tool yet, I think I'll buy this [url=
just incase I can use it without removing the stuck crank first. If not, I'll try heat/battering it off/legged puller method!
Cheers,
Andy
Bear in mind that ISIS isn't Shimano, and there quite a few lockring types out there, so they may not fit.
angle grind the crank off and use the right cup remover simples
Hammer and screwdriver on one of the notches if you don't mind damaging the BB. Don't forget drive side has a left hand thread
I did the same thing a while ago, a mate had a gear puller very much like [url=
that got the crank off very nicely (it was a little gouged up but I don't suppose you care at this point?)
