Removing decals
[Closed] Removing decals
[#5146738]
What is the best way to remove frame decals?
Posted : 11/05/2013 12:38 pm
Use neat muc-off. Might also change the frame colour and remove anodising though. Hair dryer to soften glue and wd40 or brake cleaner to remove it. Just not at the same time. Ok? 😉
Posted : 11/05/2013 12:49 pm
Warm them up with hairdryer and peel off gently.
Posted : 11/05/2013 1:03 pm
Boiling water is normally the first thing I try.
Posted : 11/05/2013 1:06 pm
Depends if lacquer had been used. If it hasn't then a hair dryer is usually the best thing.
Posted : 11/05/2013 1:13 pm
