Removing Chainring ...
[Closed] Removing Chainring bolts
[#3126337]
Hi All,
trying to replace my chainring but currently 2 of the bolts are refusing to loosen and are just spinning on my slx cranks. I have tried using the specific tools for holding the bolt in place but i can't seem to get anywhere with it.
Has anyone got any suggestions or tips that might make it easier?
Posted : 08/09/2011 11:53 am
Ahh. The tool always works for me.....
Posted : 08/09/2011 11:56 am
Hmm. If the tool isn't working, try a combination of a pack of cookies and your LBS.
Posted : 08/09/2011 12:01 pm
Can you be a bit more specific - what tool are you using, and in what way is it not working?
Posted : 08/09/2011 12:03 pm
I have the icetoolz chainring bolt tool, it like a screwdriver basically, I have tried gripping it in the vice and turning the torx key with my hand but it is just slipping, which is obviously not what you want to happen.
Posted : 08/09/2011 12:08 pm
bristolbiker, thats a pretty dumb second question. 🙄
Posted : 08/09/2011 12:26 pm
 Haze
Angle grinder?
Posted : 08/09/2011 12:29 pm
a bit of heat might work. sometimes they are locktited in and the heat should break the bond.
Posted : 08/09/2011 12:32 pm
Have you managed to get two out and now can't get the others? If so, completely removing two bolts might have added extra tension to the remaining bolts making them hard to remove.
Replace the removed bolts & nip them up so they take some of the tension out of the remaining two. The try removing them all a bit at a time.....
Posted : 08/09/2011 12:38 pm
i had one stuck and the bit the tool fit in was rounded so gripped it using these
http://www.screwfix.com/p/forge-steel-10-water-pump-pliers/37427
i opened it far enough to get one of the jaws on the nut and the other jaw on the edge of my bash guard holding it still.
might be worth a try!
Posted : 08/09/2011 12:39 pm
Try soaking the offenders in WD40 and leaving overnight to marinate.
Posted : 08/09/2011 1:01 pm
Two things you could do.
try gripping the slots in the back of the chainring bolts with circlip pliers, they have worked for me in the past.
If not, I'd assume you're removing a chainring to replace it? I've needed to dremel out the bolts before. If you can cut the chainring off the bolt you;ll have enough exposed to either cut the top off and remove the remainder, or grip with a vice or vice pliers.
once done, replace with FSA/A2Z bolts with a 5mm hex one side and 6mm hex the other. Those don't get stuck.
Posted : 08/09/2011 2:11 pm
