Hi all, thought I’d turn to the font of all knowledge that is the STW collective to try and help me save near disaster, my favourite hip flask has a leak!!! It is only a small pin hole sized leak in the bottom corner where the side meets the base, I could replace it with a new one, but I like this one, is there any remedy? As the hole is small I debated using a bit is super glue and then leaving it to harden before use, but was worried this would affect the flavour, or could such a small hole be welded? The flask is stainless steel if that helps at all..
