hi,
just checked my oil ( on an older berlingo ) and I pulled it out - checked it - wiped it and inserted it for a 2nd check - pulled out and this is the funny bit - the dip stick came out minus the plastic end which had sheared off...
I now have the 4cm or so bit of plastic stuck probably at the bottom of the tube...
now is this likely to migrate and wreck the oil pump / worse or are there filters / strainers in the way - I have rang the local garage but its on answer phone...
help please as I have a 3 hr journey tonight...
cheers
paul
