raceface/shimmano c...
[Closed] raceface/shimmano compatability?
[#3269633]
can you fit shimmano rings to a raceface crank?
Posted : 22/10/2011 6:32 pm
Yes. Race Face cranks use a standard 4 bolt 104mm BCD as do the majority* of Shimano cranks do you should have no issues at all.
Richie
*I believe some XTR models might use a different bolt pitch but as far as I'm aware all others are ok.
Posted : 22/10/2011 7:12 pm
The pitch may be the same but some Shimano rings have deep kinks that interfere with RF Cranks, my Turbines won't take a Shimano middle ring.
I'd stick to Blackspire etc. they're super tough and burley and nice an flat. they can usually be picked up cheaper too.
Posted : 22/10/2011 8:01 pm
thanks
Posted : 22/10/2011 9:49 pm
I put shimano steel middle ring on rf crank, but had to file the ends of the tabs.
Posted : 22/10/2011 9:59 pm
