DJ, Cockercombe although being run in and worked over by the DH’ers vary in smoothness a lot. North of the bottom fire road, they are tight, twisty and rooty and pretty steep in parts. South of the bottom(forest track) they are a touch smoother with many line choices, once again fairly steep but more open than the other side.
Holly bush is best found after doing the lower hare knapp descent north descent. When you pop out onto the wide grass track after the tight twisty fun section turn right to ascend south again, after about 100m look for a holly tree on your left, there’s a trail head there, that trail will bring you out at the bumps(grassy area at the bottom of Holford combe by the gate)
Lowsey comes out along side the bottom section of Slaughterhouse, past the fallen tree after the sharp left hander.
The single track traverse around the edge and east of stert heading north and traversing the western flank of higher hare knapp is a lovely ride when it’s dry. Just follow it north and let it link you up with the westwards descent from the knapp into Hodders.
