Clearly the 1st signs are a warning about the bit of uneven surface between the yellow lines. 😉
I suspect that the 2nd signs say something like “Cyclists, you can go as fast as you like now because the next bit is really smooth and you’re all really cool and groovy people” 8)
Just as well every single cylist is on Strava then.
Well, it’s a (not very representative) sample. If there’s thousands of riders out there routinely going faster than that we should let British Cycling know because there’s sure to be a world champion among them.
Well, it’s a (not very representative) sample.[/quote]
It’s certainly likely to include the vast majority of those going fast – Strava is only unrepresentative in that it is heavily biased towards those going faster, hence it appears to be an excellent way of proving the point.
Sign inaccuracy aside. There is a similar situation on the wirral way whereby the route passes through a Golf course (similar to the crossing in the pic) and so a request for cyclists to slow down as they pass the crossing would seem reasonable to me.
Yes it’s reasonable but the signs are confusing & hard to read. They should be rectangular and white & blue. You could also argue that some nice wooden posts would look a bit better & be more in keeping.
Well that depends how fast cyclists are going, and why it is they’re being asked to slow down. Given a median speed well below 18mph, it doesn’t appear that speeds are currently that silly, or that there’s really any danger with them.
it also only requires you to slow down, with no instruction by how much or what to.
So a quick sprint up to 30mph on the lead in, coast over the marked section at 28, having slowed down as instructed, and then speed up again the other side.
Zilog – you’d love the climb up through Boonbeck nr Lorton (basically the C to C route up to Whinlatter). The drainage grates on the road have been replaced with awesome new ones that are aligned to grab the front wheel of a road bike (mountain bikes and crossers are ok).
Instead of fixing the problem, some genius in the local highways has put up ‘Cyclist Dismount’ signs (six sets…) at a cost of who knows what 🙂
At least they aren’t “CYCLIST DISMOUNT” signs… they really grind my gears!
Some new ones of those have appeared a few miles away from the original pic, on the pavement of the road bridge at Langley Park. Interestingly, the pavement is not a designated cyclepath but – well, dismount anyway!
