PSA: XT M785 Brakes
[Closed] PSA: XT M785 Brakes
Thanks for the heads up!
Posted : 22/08/2011 8:48 pm
Anybody know what delivery times are like.
Cheers for the Facebook help. Absolute bargain.
Posted : 22/08/2011 8:55 pm
Done it! Two pairs + an XTR bottom bracket!
Just a heads up for those going more blingy. Merlin have 2012 XTR brakes for £300 inc rotors...
Posted : 22/08/2011 10:12 pm
I'm having second thoughts about the XTR BB - someone told me that the only differences between xt xtr and saint is the amount of sealing? Had problems with grit getting in the bearings already with my xt.
Posted : 22/08/2011 10:35 pm
 tron
Delivery is generally pretty quick. About 4-5 working days.
Posted : 22/08/2011 11:01 pm
I am so tempted by these...
What needs to be bought to shorten the cables (and swap levers around)?
Hoping just Mineral Oil and some tubing.
Will the olives in them already be reusable?
Posted : 22/08/2011 11:07 pm
Can older 9 speed XT M770 shifters be made to work with the iSpec mount?
Posted : 22/08/2011 11:13 pm
I was going to ask the same: will we need new olives to switch them around?
Posted : 23/08/2011 12:00 pm
you can get away with reusing olives, but if it doesnt seal then you need to replace them. For the sake of a couple of quid Id get some olives in ready for the swap so that you dont have to wait for them to be able to test your lovely new brakes 🙂
http://www.on-one.co.uk/i/q/BSSHSMBH59/shimano-olive-ring-set-fit-sm-bh59-y8h298020
http://www.chainreactioncycles.com/Models.aspx?ModelID=1801
EDIT its infuriating that theyre so expensive. I was lucky to get 10x sets as a bulk buy of eBay once. Same with powerlinks, got 10x for a fraction of the cost of 10x individuals.
Posted : 23/08/2011 12:04 pm
Still haven't had a reply about the pads.
Posted : 23/08/2011 12:07 pm
One thing to bear in mind with these brakes is they use a different hose insert to the older brakes. So if you plan to cut the hoses down you actually need Shimano part number 8JA 9802. If you just intend to swap them and use a new olive then the older part number that Stoner links to will be fine, just use the olive and discard the insert. Or you could buy just an olive, part number 8H2 0400.
Posted : 23/08/2011 12:13 pm
Anyone thinking of buying the XTR brakeset just to be clear that these are the 'race' set not the 'trail' set i.e. you don't get the free stroke adjustment.
huh?
it says M988 which is the code for the trail lever
race and trail use the same calipers, the M985
the race levers are M985
not sure why you think they are the races
Posted : 23/08/2011 12:14 pm
Just buy the olives from Rose! They're only 90p!
http://www.rosebikes.co.uk/article/shimano-olive-incl-insert/aid:198833
Edit - and delivery times are really quick. I think my brake pad order (which are also really cheap from Rose) arrived in 3 days.
Posted : 23/08/2011 1:05 pm
On the Rose website it looks like a copy and paste error as both the Race and Trail brakes say M985 in the header. The products themselves look correct to the descriptions.
Posted : 23/08/2011 1:18 pm
I picked up the deore version cheap for a second build and I'm just wondering what insert is need?
These brakes:-
http://www.rosebikes.co.uk/article/shimano-deore-disc-brake-br-m596/aid:516076
Do I need a different olive to the one in the link above?
Posted : 23/08/2011 1:20 pm
Cheers mister p.
Wish I'd've thought of these things before I ordered. I was worried that there'd be a rush on the brakes and they'd be gone before we could all import a load.
Posted : 23/08/2011 1:43 pm
The BR-M596 brakes use the new brake hose SM-BH90 so you need the silver insert, part number 8JA 9802.
[url= http://techdocs.shimano.com/media/techdocs/content/cycle/EV/bikecomponents/BR/EV-BR-M596-R-3206_v1_m56577569830759433.pdf ]BR-M596 diagram[/url]
In fact if you look at the link to the olive and insert on the Roase website it actually lists it as "Attention! Not compatible with Shimano brake cable SM-BH90"
Posted : 23/08/2011 1:56 pm
Bought some olives, will just use the old insert (unless I lose it, which isn't out of the question)!
Posted : 23/08/2011 1:58 pm
I'm not on Facebook, can I still use the code?
Posted : 23/08/2011 5:47 pm
nmdbase -
The finned pads are one-piece but you can 'normal' pads without the fins.
Another bonus is that they are now symmetrical so you can switch them around if they are wearing unevenly.
Although the finned pads are labelled L & R but not sure why. Airflow?
Posted : 23/08/2011 6:14 pm
BR-M596 diagram
My bad. You'll want these:
http://www.rosebikes.co.uk/article/shimano-olive-incl-insert-485535/aid:485537
Posted : 23/08/2011 7:38 pm
I was a touch worried as i'd put up the PSA over the weekend before they could ship the brakes and thought afterwards that with the rush, I might end up getting none.
Good news, they are in the country according to the DHL tracking info.......
Looking forwards to getting them, but haven't got any olives (or inserts) which was a touch silly. Have to find some of the correct ones from the uk.
Posted : 23/08/2011 7:43 pm
Thanks Entonox, what I wondered is if it came with the finned pads or standard ones/
Posted : 23/08/2011 7:53 pm
Bike 24 have them too if Rose go out of stock.more money at bike 24 though..
i ordered off Rose in the end,
the lever looks shorter,which i like..
gonna swap to some other hoses goodridge or somet,which should be ok with normal olives etc right?
Posted : 23/08/2011 8:14 pm
You should get the olives and inserts in the kit. I did with my XTRs from Germany.
Posted : 23/08/2011 8:19 pm
Surely we should get olives and inserts in the box?
Edit .... Just seen above.
Posted : 23/08/2011 8:22 pm
nmdbase - My SLX came with sintered finned.
My friends XT came with the same.
Both ordered from different German online shops.
Posted : 23/08/2011 8:44 pm
Thanks mate, order time 🙂
Posted : 23/08/2011 9:00 pm
Seems too good to be true, but I'm in for a few bits...!
Posted : 23/08/2011 9:33 pm
Just ordered some too - assume they'll work Ok with my Hope rotors and adaptors?
Posted : 23/08/2011 11:41 pm
 Xar
I've jumped on the band wagon as well.
Possably a silly question about swapping the levers around, the above posts say all you need is the olives but wouldnt you lose some of the oil in the hoses and need to bleed them as well?
Posted : 24/08/2011 7:47 am
I expect to bleed them when swopping but can't see why you need an olive unless you shorten the hoses.
The olive will be compressed onto the hose at the insert so unless shortening the hose it should be fine.
Posted : 24/08/2011 7:55 am
The oil shoud stay in if you cut carefully and keep the hose upright.
Posted : 24/08/2011 7:56 am
 Xar
Thanks Dickie and Mosey.
Posted : 24/08/2011 8:33 am
ooh they've arrived
good timing - picking up new bike to put them on later today as well
Posted : 24/08/2011 10:00 am
Couldn't resist a quick peek. They come with normal pads - not finned (OE brakes I guess).
Levers are so tiny, I can see why somebody above runs them outside their shifters!
Nice free mug included too.
Posted : 24/08/2011 10:05 am
Excellent, mine should be here today too.
Got emailed a 10quid credit note from them for the Facebook voucher.
Plus a free mug to go with my bowl?
Can't be bad 🙂
Posted : 24/08/2011 10:34 am
BTW, for those that asked, I'll be doing the hose swap (have done it a few times before), so will do photie instructions for posting up here.
Posted : 24/08/2011 10:36 am
I'm in too. To be honest, even at full RRP these seemed great value. £125 a pair is mental.
DezB - I'll probably be making use of those instructions, cheers.
Posted : 24/08/2011 10:43 am
 S_J
I've jumped on the bandwagon as well! Couldn't resist at those prices.
I'm assuming the adaptors haven't changed to mount the calipers? Hoping to re-use the Shimano ones I've got already
Posted : 24/08/2011 11:09 am
Mine arrived also. They come with one spare olive and connector (you only need to buy one if you're planning on doing new ones). Can confirm non-finned pads. Levers are tiny tiny tiny.
And a free mug, and two packs of free sweeties. And my XTR BB.
Posted : 24/08/2011 1:00 pm
I've read a good plan for the hose swap without bleed is to take the bleed block out, engage the lever a little to push the pistons out, then when reattatching the hose, use a spacer to push the pistons back in, pushing fluid through the system until you have a meniscus at the end of the hose.
Make sense?
Posted : 24/08/2011 1:02 pm
DezB - good lad!
So for those of us that want to shorten the hoses, even if I'm careful with the cut I guess there would be some leakage. Can I just put a bit more fluid into the hose before reconnecting?
Posted : 24/08/2011 1:11 pm
continuity, i have used that trick of "burping" when Ive shortened hoses-this is on used brakes so already have some piston movement to push back with. Worked fine every time.
thebunk, see above, if youre careful you wont even need to top up fluid. This has been mentioned in a few brake bleed threads, if you forum search "M775 brakes" youll probably find a few blow by blow how too guides as these brakes seem to cause a few headaches.
Posted : 24/08/2011 1:23 pm
Mine arrived today.
I went for the silver ones.
They came with a mug and a couple of bags of sweets.
Amazing price and service, I'll use them again!
Now to fit them...
Posted : 24/08/2011 1:34 pm
Page 2 / 11
