Viewing 3 posts - 1 through 3 (of 3 total)
  • Probably daft 9spd > 10spd Chain ring / front mech question.
  • giantonagiant
    If making the change from 3×9 to 2×10, do I need to change front rings, or just drop the big ring, stick a bash guard on and set the limit on front mech to middle ring?
    Or are these bits specific to 10 spd too?
    Thanks.
    goldfish24
    Yep that’ll be fine. Chain rings only care about the inside diameter of the chain, which is te same for 8,9,10 speed. Also, you won’t ‘need’ a bash ring, mech should keep the chain on. Of course you can have a bash if you want though.
    giantonagiant
    Good stuff, thanks goldfish, just what I thought / hoped.
The topic ‘Probably daft 9spd > 10spd Chain ring / front mech question.’ is closed to new replies.
