If you choose an answer to this question at random, what is the chance you will be correct?
a) 25%
b) 50%
c) 60%
d) 25%
Apologies for the lack of aeroplanes, conveyor belts, Picolax and the number 2.
a) 25%
b) 50%
c) 60%
d) 25%
My brain started to smoke a bit after 20 seconds so Immagonna wait and join in later.
0%. But I hate probability. So could be wrong, but I don't think so.
1 in 3 chance
Assuming 25, 50 and 60 % are equally like to be correct then
(1/3 * 1/4) + (1/3)*(1/4) + 1/3*(1/2) = 1/12 + 1/12 + 1/6 = 4/12 = 33.333%
But surely you do not need the maths and it is obvious?
EDIT - few dodgy ( )
50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%, no... 25%, no... 50%....
Either no one else has understood the question properly, or I'm thinking about this too deeply.
GJP - I got 33.3333........% (or 1 in 3) without any maths. There are three possible answers and you are picking one of them. Surely?
So, if you answer any four answer MC question at random, there's a one in four chance of getting it right i.e. 25%. But two of the answers are 25%. So is it now 50%?
I think the confusion (or twist/brain ****) is, is that the actual answer, isn't one of the answers.
It's impossible to choose an answer 'at random' surely.
RealMan = 0% isn't an option, so...
No darcy - if the actual answer is 25%, then you have a 50% chance. if it isn't, then you don't.
*edit* - that was my first approach anyway, but isn't correct
*pulls up a chair*
ATSR - yes you are correct and that is the intuitive approach - I needed to derive it from first principles - you are probably a lot younger than me and my brain is fecked
Although to my credit I actually stated the key assumption that all unique answers were equally likely to be correct whereas it was implicit within your intuitive thinking
If you choose an answer at random, what is the probability you will be correct.
So you choose an answer, it won't be correct => probability = 0%.
Or something.
This statement is false, innit?
b)
50 % it is either right or wrong the number of choices is irrelevant I suspect the exact wording of the Q is critical to the answer.
There is no question
Surely there is no spoon...
Anyway, it's a paradox... of similar making to the one with the book that lists all books which don't reference themselves.
Yeah, you also have a 50% chance of winning the lottery, cause you can either win or lose, right?
Yes well spotted.
You cannot deny that each week i either win it or i dont there is no other chance. Obviously the odds/probabilities heavily favour one outcome but there are still only two chances hence 50%
I think the key is the word chance here and it is the semantics of the Q that is the issue here. It cannot be probability as others suggest as that would give 33% which is not an option.
Anyway I have more chance of being right than you as I went for an answer that was at least there
So there is zero chance you'll be right?
There's two questions, with a similar set of answers, which is confusing. Compare,
a) A
b) B
c) C
d) A
Answer, 33%.
Probably.
It's self referential, so it's a paradox and hence cannot be answered.
I'd be impressed if someone's come up with a new one though - there must be a recognised and named version of this problem surely? Game theory anyone? CharlieMungus to the forum, please.
that is some cruel mocking of my maths ability there grahamS
Yes I should have realised its the opposite of what I think as this does seem to be the rule with any maths question on here
I did a bit of Googling.
I've seen suggestions that it's paradoxical and there is no answer, with "Russell's Paradox" posited. Frankly that's beyond me, set theory to that degree makes me want to kill kittens.
I also found this analogy, which is ostensibly where I was going with it, only a bit better written:
There is a box containing two red balls, one blue ball, and one yellow ball. I secretly write down one of these colours on a piece of paper.If you pick a random ball from the box, what is the probability that the ball is the colour written on the piece of paper?
Answer, 33%.
I'm convinced this is correct now, though the maths was breaking my head for a while.
Using the 'balls' analogy, cos it's easier; you pick a ball at random, what's the probability that it matches what's written on the paper? The key here is that the contents of your ball bag doesn't matter(*). Whether you've got two red balls, a hundred red balls, or in fact only red balls, what are the chances of it matching a 1-in-3 random choice? It's 33%.
(*) - never thought I'd find myself typing that
Ooh, I think I've got it. Is the answer to this question no?
No.
I'm now questioning my own theory actually - if there are 100 red balls, one blue ball and one yellow ball, the chance of picking the yellow ball is 1 in 102.
Therefore if the answer is yellow (or blue), it's 1 in 102, whereas if the answer is red, you have a 100 in 102 chance?
Aaaaarrrgggghhhh!!!!!
Do I need to stand on a conveyor belt for this one?
Just for the record, anyone that thinks a plane on a conveyor belt would take off is a dumbass.
thankyou Cougar
it only took one post!
I want to win a goat. Which choice do I make for that?
A looong time since I was at school - can you add probabilities together like fractions, because if so, it revives the 1/3 theory
Red - 2/4
Yellow - 1/4
Blue - 1/4
Add together = 4/12 or 1/3
Works for 5 balls too, with 3 being red
Red - 3/5
Yellow - 1/5
Blue - 1/5
Add together = 5/15 or 1/3
Or is that just a load of nonsense?
You must log in to post.
