Hi,
I bought a frame that has a Pressfit BB shell(68mm)…I wasn’t interested in that and had planned to use an adapter so I could use a normal BB. I’ve just got the adaptor but on reading the instructions, they state it can only be used with a 68mm shell if it’s on a road bike! It seems that you don’t use the normal 2.5mm spacers on the cups, you use some other spacers inbetween the BB and chainset instead. What makes it worse is the fact the adapter is made by SRAM, the instructions show the correct spacing when using a GXP/Truvativ chainset, I’m sure they’re spaced differently to Shimano/Raceface anyway?
Is my only option to send the adapter back, buy a PressFit30 BB and use the Problem Solvers adaptors so I can use my ordinary chainset?
Thanks for any help with this.
