'Play' In...
[Closed] 'Play' In cassette.. normal?
[#3765584]
So I was cleaning my bike after a ride yesterday and decided to take the cassette(10speed shimano) off to give it a proper clean.
Before I removed it I noticed that if I grabbed the cassette and wobbled it there was a small amount of play- I could feel the play and see it moving in relation to the axle. At most it was 0.5 - 1 mm of movement.
So what's the story? Bike has had moderate off road use, i'm still on the first chain/cassette/chainset but my park tool indicates the chain isn't worn.
Is the freehub goosed or can it be adjusted?
The wheels are Bontrager rhythm comps
Posted : 12/03/2012 2:25 pm
Was the play directly in line with the axle, or did it 'wobble'?
Could be that the lock-ring wasn't tight enough.
I have Rythmn Comps and have not noticed any particular problem.
Which cassette do you have?
When you take the cassette off, does the freehub have play in it?
Posted : 12/03/2012 2:28 pm
I've noticed this on a few of my bikes and so, putv it down to just something that happens... Am I right though...
Posted : 12/03/2012 2:29 pm
A little play in a freehub body is normal. Presume cassette was tight?
I'm running Bontrager Rhythm's and there' is a slight bit of play in the cassette. At first I thought it might be wheel bearings. The LBS put new ones in and when I mentioned the play in the cassette, they said that was normal. Its certainly not bad enough to cause any problems shifting
Posted : 12/03/2012 2:35 pm
I've no problems shifting and can't notice it riding, just when I came to take it off I thought to myself "Is that meant to be like that?"
The play could be felt in the freehub with the cassette removed. The cassette is XT I believe. The lockring was tight before removal and I tightened it up after cleaning and the play was still there.
Perhaps it's nothing, it's not something I checked when the bike was new though so it's difficult to tell if it's 'just like that' or is a problem developing.
Posted : 12/03/2012 2:44 pm
You take your cassette off to clean it?
Posted : 12/03/2012 4:13 pm
There is usually some axial play in the hub body when the wheel is out but not when it's in the frame
Posted : 12/03/2012 4:14 pm
Don't normally take it off to clean, never done it on this bike and it was nice and sunny yesterday after the ride so I thought i'd have a bash 🙂
Posted : 12/03/2012 4:16 pm
Have you made sure your lock ring is tight?
Posted : 12/03/2012 4:17 pm
 mrmo
cassette moving on freehub body, bad, freehub body moving a little in relation to hub, ok as long as it is only a little.
Posted : 12/03/2012 4:55 pm
A tiny bit of play in the cassette is normal, taking it off to clean it is not 😉
Posted : 12/03/2012 5:00 pm
Not sure with bontys but I have mavics with the nylon freewheel bearing that wears and gives a lot of play. We are talking easily 3mm. If yours has a nylon bearing lube as per the service instructions and dont worry about it. I take it your gears are changing smoothly enough?
Posted : 12/03/2012 5:14 pm
i had the same problem, it wont be the casette it will be the free hub that it sits on, i took mine to my lbs to get a freehub service and the play has gone 🙂 try that
Posted : 12/03/2012 5:18 pm
Same problem, same hubs & cassette - I've replaced the bearings - 15quid all together - seems fine now
Shop wanted 50!
Posted : 12/03/2012 9:43 pm
