Pike Spring Issue
[Closed] Pike Spring Issue
[#821464]
Hi guys
I'm changing my spring over to a softer one at the moment. I've unscrewed the top, taken out the lower screw and now i need to just slide the coil out. However the coil is not moving whatsoever - any thoughts. Do a just use brute force and yank the thing out or some other more subtle approach.
Help badly needed as i'm off to the alps tomorrow and the fork is ****ed at the moment.....
Posted : 28/08/2009 9:25 am
Is it a u-turn ?
Posted : 28/08/2009 9:37 am
Put the hex head bolt back in the bottom about half way and hit it with a rubber mallet
Posted : 28/08/2009 9:41 am
....and keep it on its side as 15 or 20cc of oil should fall out the hole otherwise.
good guide on tftuned website if you get stuck.
Posted : 28/08/2009 9:42 am
Also do it with the fork levet horizontally so the oil doesn't drain out, or be prepared to put some new stuff in
Edit- too slow!
cheers guys i clobbered the hex head bolt at the bottom with a mallet and it dislodged the rascal....all fixed up now for chamonix!
Posted : 28/08/2009 9:58 am
