I actually had a change of mind at point of ordering and went for a firm - so cheers craig, but not necessary.
fivespot - When TF tuned serviced my forks a couple of weeks back they recommended a stronger spring. I declined (because I could only just afford the service having been to the alps the week before - where I f**ked my forks up!). The engineer did warn me that if I started bottoming them out then putting more compression damping on would only screw the seals in the motion control (again). I noticed when they got returned that the sag seemed a little more than before, and when pumping through a section yesterday they bottomed right out - hence me thinking of a stronger spring. I did notice that the rebound was set to a much slower setting than I would normally have so I gave it a couple of turns and it seemed a little better.
Mark - thanks for the chart. That was exactly what I was looking for. I would agree with Peter from that chart that RS seem a little OTT.
I'll give the firm a blast for a bit and see how I get on.
