Hello again after getting plenty good advice a couple of days ago, I ordered th TFTuned lowers service kit (which arrived next day i.e today). So I followed the instructions and got the lowers off no problems with a little bit of mud/water/oil coming out as expected. Next step remove the foam o-rings and problems begin, both of them are partially wedged under the seals that house them, arghhhh. Maybe I dont need to remove them after all. Check instructuions/manual etc. Yes I do need to shift them and clean them.
Grunt pant panic
I have removed them but they are more erm… C shaped than O shaped, the good news is that I have managed to coax out the remainder from the seals. I then notice that the left upper is scratched and worn in rings starting about two inches from the bottom and in two inch intervals untill just below the exposed section….? The other upper is fine. What could have caused this and how can I make it better.
Will the nice TFT people sell me just the foam rings or do I need to spend £30 on a seal kit …sigh.. as I said ‘gutted’ and I tried so hard.
Oh the anodizing is already disappearing from them as well. I will do better!
