Permanent cable sto...
[Closed] Permanent cable stops for Titanium frame
[#2778663]
I have a titanium frame that has no permanent gear cable stops, just glued on plastic stops running along the downtube and right hand chainstay for the rear derailleur.
I would like to replace them with something more permanent and be able to eaily run a front derailleur
What are my options?
Here are photos of current positioning both permanent and non-permanent.
Below disc brake cable guides running along top tube.
Temporary plastic stops running down the downtube
...and further down
Disc brake cable guide on left chainstay
Advice appreciated.
Ackie
Posted : 22/05/2011 9:35 pm
Not sure if there's anyone in the uk who could weld new ones on.
Posted : 22/05/2011 9:40 pm
weld? would you need to? with steel and alloy frames the cable guides are often/usually silver soldered in to place. Not sure if silver solder will wet the surface of Ti but assuming it does then adding cable stops would be a piece of pish wouldn't it? for a frame biulder....in fact anybody competent at a bit of soldering might do it....but don't take me as gospel on this.
Posted : 22/05/2011 9:47 pm
Enigma Bikes would be able to weld stops/guides on for you no problem.
Posted : 22/05/2011 9:49 pm
Glue ? Something industrial.
Posted : 22/05/2011 10:43 pm
Steve Potts
Look at my profile pic to see the disc mount he added to my old Merlin.
Beautiful but not cheap or local.
Posted : 23/05/2011 12:36 am
Find a local metal fabrication shop. Look here for bits http://www.alibaba.com/showroom/bicycle-cable-guide.html
Bring one to the other. problem solved.
It will be easier than you think
Posted : 23/05/2011 1:03 am
I'd have thought such a niche frame would fetch a pretty penny on here, enabling you to buy the geared frame you want!
Posted : 23/05/2011 8:12 am
the guides on my Pegasus are pop riveted on
[url= http://farm5.static.flickr.com/4130/5001827418_c021719dac_b.jp g" target="_blank">http://farm5.static.flickr.com/4130/5001827418_c021719dac_b.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/rocketdog/5001827418/ ]wings[/url] by [url= http://www.flickr.com/people/rocketdog/ ]rOcKeTdOgUk[/url], on Flickr
Posted : 23/05/2011 8:27 am
