Hey all,
Just a bit of advice on my new purchase, a Y reg Bora. From when I picked it up Sunday it has had a problem. I think I know what it is but wanted to make sure before I take it back to the dealer to be sorted.
When in 3rd for example, sitting at 2000rpm and you accelerate hard the car revs then launchs forward, as if its catching up with itself. I believe its the clutch plate wearing out but not quite gone but I might be wrong?
Also, noticed the clutch pedal wasent returning properly last night, but it hasent done it since. Im guessing thats an issue with the master cylinder but these engines have notorious problems with dual mass flywheels, but a flywheel issue shouldnt affect the physical use of the clutch surely?
Any helps would be appreciated!
Doug
