On-One Thinny Pedal...
[Closed] On-One Thinny Pedals
Best start reading up on who does good sq taper bbs then
Posted : 28/02/2012 9:11 pm
With pleasure AndyL
[url= http://www.flickr.com/photos/monotokpoint/sets/72157624201550137/ ]Clicky ----> ** Airbourne Lucky Strike Ti Pics **[/url]
Have made a couple of changes since I took these pics. Shortened the brake cables (to look tidier), changed the crankset to a Middleburn Duo set up and as of today, the pedals!
Posted : 28/02/2012 9:16 pm
Mine arrived this morning too - 9.30am! From order to delivery, less than 24 hours. Nice. Oh and their lovely, good size and grippier than the ones I had on.
Posted : 28/02/2012 9:51 pm
Not sure about the lack of a concave surface, might not get on with mine.
Posted : 28/02/2012 9:59 pm
Just had a look (one eye shut, pedal face on, laying on the floor - looked a bit wierd!) and they look perfectly flat to me
Posted : 28/02/2012 10:40 pm
hmm that airbourne is beautiful want a Ti Hardtail now 🙁
Posted : 28/02/2012 10:50 pm
Me too. If you do a Ti hardtail it has to have Ti post, bars and mainly silver bits but with the odd little touch of colour for contrast.
Posted : 28/02/2012 11:03 pm
Thanks s4rpf and andyl. Was always a DH/Freeride biker until about 3 years ago and it took me a while to get the right frame for a HT. I think it's the one bike out of the lot I will never sell!
Posted : 28/02/2012 11:09 pm
 flow
KMC do not make Shimano chains.
Posted : 28/02/2012 11:13 pm
Tried the pedals on the bike with appropriate 5.10 footwear. All feels good.
The pins are not locktighted in and all on one pedal were loose so worth having a quick check over. I might try to find small washers to calm down the pin length a bit as I have never required massive pins. Will probably remove a few of the centre ones as well.
All good :mrgreen:
Posted : 28/02/2012 11:40 pm
brant - Member
At least I know how many pedals I can sell in a day if we hit the right price point and have the right product
Not sure you do, Brant ( 🙁 )
Posted : 28/02/2012 11:46 pm
Good call mr plow, will check them over too. Got 5.10's here also. Reckon these will be friends with the Thinnys! 8)
They make some of them, not all..
Mr. Plow I will give you £40 for yours!
Posted : 29/02/2012 12:47 am
flow - Member
They make the HG53 and 73 chains.
Posted : 29/02/2012 12:58 am
I've said it before, but that Lucky Strike is absolutely stunning. One of the nicest user bikes on here, IMO.
Posted : 29/02/2012 10:38 am
there appeared to be a set of silver ones still available as of this morning.... Lets just see if they come,,??
Posted : 29/02/2012 12:54 pm
 robh
monotokpoint- what front mech are you using with the Middleburn and are they Sram shifters?
Posted : 29/02/2012 4:38 pm
Using Sram front mech (think it's top pull, but will check later) and X0 shifters (2x9 set up)
Posted : 29/02/2012 6:45 pm
Thinnies are good innit !
Posted : 02/03/2012 10:45 am
got to admit I'm a little disappointed in mine... most of the pins on one pedal will not tighten up and are rattling... have emailed on one though will wait and see what they say can be done.
Posted : 02/03/2012 11:41 am
2 on mine won't tighten fully so I've just used a bit of loctite. The problem is with the pins I think, the thread doesn't run to the very top so you can wind them past their thread.
Posted : 02/03/2012 1:06 pm
If you dont want 'em I'll have 'em!
Posted : 02/03/2012 1:25 pm
I'll try the thread lock first... but it does seem that the thread is a little wide and there is physical play between the hole and the pin.
Posted : 02/03/2012 2:16 pm
suppose it is the pins, does anyone want to tell me the exact size pins I would need to buy to replace the current ones, I can push one of the pins in by hand! 😐
Posted : 02/03/2012 6:29 pm
Mine are all tight for what its worth
Posted : 02/03/2012 7:53 pm
Yep same, just checked mine and they are as tight as a nut (or pin).
Posted : 02/03/2012 9:42 pm
all of the screws on one side of one pedal just won't bite... I've tried moving a pin from the holes that do bite and they still don't grip. As I stated before, but now I can push a few of them in... might have to get them re-threaded and use bigger pins 🙁
I have emailed on one just in case you were wondering, nothing back so far.
how long does loctite take to bind? they're still wobbly.
Posted : 02/03/2012 9:56 pm
Shouldn't take long too long to dry, but maybe overnight to cure, so to speak. Check again in the morning to see if the pins hold. I can understand your frustration - it's really annoying when you get some new kit that's faulty. Had that a couple of times recently! I hope On One get back to you sharpish!
Posted : 02/03/2012 10:07 pm
Just checked through my mail properly and they had replied (so apologies for that) they have suggested thread lock.
I honestly think the holes are too big for thread lock to make a difference, you can physically wiggle the pins in the holes.
Its just frustrating there aren't any left so I will be able to send them back as faulty I'm sure with full refund but I won't be able to get these replaced.
I will leave to harden overnight.
Posted : 02/03/2012 10:16 pm
the screws are churned out by the 1,000,000,000,000,000 so my money would be on the pedal body being at fault.
If they are really moving around then threadlock isn't the way to go, however a bearing retainer (or simply some Araldite) might work.
Personally I'd be sending them back
Posted : 02/03/2012 10:25 pm
I think I may well have to send them back...
Posted : 02/03/2012 11:00 pm
thread lock has made no difference at all...
Posted : 03/03/2012 3:03 pm
Sorry to hear that [i]passtherizla[/i], please return for full refund :-/
Posted : 03/03/2012 3:15 pm
no worries brant, these things can't be helped, they look awesome I'm sad to have to send them back. 😥
Andy.
Posted : 03/03/2012 6:23 pm
If it's any consolation I might have identified a replacement. I'm off to Taiwan tomorrow to sort it 🙂
Posted : 04/03/2012 10:41 pm
I think I may have resolved the issue.. Found marginally bigger than standard bolts and they lock up fine no worries, think the standard are M2.5 8mm and I have just chucked in some flat head stainless M3 and cut them down to size. Not a fan of having to send stuff back especially when there is no chance of it being replaced. I didn't have to re tap and di the holes or anything they just went straight in.
Posted : 05/03/2012 11:56 am
double post
Think Im going to source some some shorter pins for mine.
Posted : 05/03/2012 12:08 pm
Dibs on some of those then, especialy if they're near burgtech sized platofrms, it's the size (and resultant epic levels of grip) that I like about them.
scruff - Member
I was thinking about this too.. they are pretty severe aren't they! might be worth re threading all the holes and going with slightly wider and shorter pin...
might see if something like this will fit
http://www.chainreactioncycles.com/Models.aspx?ModelID=60911
I love fiddling with stuff so I don't mind having to do this, and they were only £40 even if I had to flip the faulty pedal over to the good side all the time it wouldn't be such a hassle.
Posted : 05/03/2012 12:13 pm
I've lost 2 pins in 2 rides, think they all need loctite. Anyone worked out the pin size ?
Posted : 11/03/2012 7:08 pm
I'll talk to myself then.
[url= http://www.ebay.co.uk/itm/ws/eBayISAPI.dll?ViewItem&item=300644333854&ssPageName=ADME:L:OC:GB:3160 ]http://www.ebay.co.uk/itm/ws/eBayISAPI.dll?ViewItem&item=300644333854&ssPageName=ADME:L:OC:GB:3160[/url]
[url= http://www.ebay.co.uk/itm/ws/eBayISAPI.dll?ViewItem&item=290636175044&ssPageName=ADME:L:OC:GB:3160 ]http://www.ebay.co.uk/itm/ws/eBayISAPI.dll?ViewItem&item=290636175044&ssPageName=ADME:L:OC:GB:3160[/url]
Posted : 12/03/2012 9:34 am
Any news on a replacement Brant?
Posted : 03/04/2012 3:43 pm
Thread resurrection time...
The bearings on my thinnys have started making a right old racket. Does anyone know what size they use? (I emailed on-one but they just said take 'em to a bearing supplier to find out)
Ta very much.
Posted : 13/09/2012 10:59 pm
Page 2 / 3
