Hello all,
The hubs on the wheels that came with the Prophet (Formula 20mm front and Cannondale QR rear) are starting to get tired. Front is free running but rumbling, and both ends have developed play.
Anyone got any ideas on servicing/replacing bearings? I suspect the rear hub will be fairly straightforward, but there is no obvious way into the front hub – retaining ring on the non-disc side seems to be a press fit, and the bearings would have to be drifted out from the disc side. Google has produced no results. Is it a case of giving them the distance test and replacing with new hubs or wheelset?
