Numpty IT question
[Closed] Numpty IT question
[#1764976]
I've discoved thousands of files in a Windows/Temporary Internet folder. Most are DAT, TXT and text documents. Any reason I shouldn't delete them, or perhaps more to the point any particular extensions I should keep?
Posted : 03/07/2010 9:58 am
better to use a cleaner app as they generally know which can be deleted safely. Havent used one in ages though.
Posted : 03/07/2010 10:01 am
You should be able to delete them all. They are in a temp folder after all.*
*I am not liable for exploding computers.
Posted : 03/07/2010 10:03 am
Cheers Jamie, your disclaimer tells me I should wait for further replies before hitting delete 😉
Posted : 03/07/2010 10:07 am
Wipe them via Options in Internet Explorer.
Posted : 03/07/2010 10:43 am
 D0NK
anything in a temp or "temporary..." folder can be deleted, aslong as you have no other apps running at the time eg don't delete temp files while you have your life's work open in word 🙂
Posted : 03/07/2010 10:55 am
Download [url= http://en.wikipedia.org/wiki/Ccleaner ]CCleaner[/url]
Run it.
Job done.
Actually, also you should find some disk de-fragmentation software as well and run it periodically to keep your computer running at optimum speed.
Posted : 03/07/2010 1:27 pm
Use [url= http://www.geekstogo.com/forum/index.php?autocom=downloads&showfile=187 ]TFC[/url], it's like CCleaner only better.
Posted : 03/07/2010 8:58 pm
Use TFC, it's like CCleaner only better.
How so?
Posted : 03/07/2010 11:17 pm
Cougar - it seems it might be a bit more aggressive at removing temp files than CCleaner, but from it's description it doesn't seem to either clean the registry or to give users the option of disabling programs set to autostart.
Posted : 04/07/2010 8:02 am
