Numpty DIY question...
[Closed] Numpty DIY question - do plastic central heating pipes bend?
[#3800554]
Going to do some painting. The central heating in the house is all plastic pipes - not encountered this before. The radiators feel like they should just lift and lay away from the wall. So...
Can you just lift the heater and pivot it around its base? I'm working on the pipes flexing enough to allow this. I'd still be proping the heater up off the ground by a few inches.
Posted : 22/03/2012 10:49 pm
Disconnect it, properly.
Or invest in lots of buckets.
Posted : 22/03/2012 10:51 pm
They don't bend much before 'yielding'. And if the joints aren't connected perfectly you can get pretty wet pretty soon.
Posted : 22/03/2012 10:55 pm
Do it. What's the worst that could happen? If the worst dose happen just say man on the internet said it will be ok.
It will be ok.
Posted : 22/03/2012 10:58 pm
Life was so much easier with copper, thanks, will go for caution.
Posted : 22/03/2012 11:06 pm
why? would you have "just lift the heater and pivot it around its base" if it was copper pipes?
Posted : 22/03/2012 11:10 pm
No, because its fairly obvious they aren't going to flex.
Edit - thats half a statement. its flippin obvious they arent going to flex where as its not, to me, with a plastic pipe.
Posted : 22/03/2012 11:11 pm
The pipes have a bendability in them its where they conect to the joints that dont, so easy to disconect a joint and then whoosh, dirty brown water everywhere.
Posted : 22/03/2012 11:13 pm
 Bear
As a plumber I can assure you life wasn't easier with copper......
(although still like getting my blowtorch out and doing some nice soldering, especially on bigger copper pipework)....
Posted : 22/03/2012 11:14 pm
Im still novice enough to love soldering copper. Except when trying to do it with filthy "college" flux. 3x shots at one joint earlier this week because of crap in the flux grrrr.
Posted : 22/03/2012 11:18 pm
Just surprised the rad drops aren't in copper then onto plaggy under the floor.
Posted : 22/03/2012 11:19 pm
Ok, it terms of looking at something and knowing how complex its going to be to do. Copper was much simpler - you look at it and know its going to be a job to sort. Plastic on the other hand looked like it might just be as simple as... and it turns out its not.
 Bear
Stoner - bad workman and all that........!
(I wash my brush out when the two guys who work for me have used it as it usually looks like a road sweepers broom!)
Posted : 22/03/2012 11:23 pm
yeah yeah 🙂
though I did get introduced to some weird fittings - ones that you have to flare square cut (hacksaw not slice) copper pipe to take a large internal brass olive. Apparently course setters need students to meet these things, despite them costing £10 a fitting and no one uses them! 😉
Posted : 22/03/2012 11:26 pm
I'd say if you can lift the rads up then you should be able to move them back an inch or two to paint behind without problem, have something to rest them on, they are not light.
Posted : 22/03/2012 11:37 pm
tool for the job 😉
[img] http://s7g3.scene7.com/is/image/ae235?$p$&layer=0&size=281,281&layer=1&size=281,281&src=ae235/24768_P [/img]
Posted : 22/03/2012 11:42 pm
You've just photo=shopped that 😉
Posted : 22/03/2012 11:45 pm
I think I sat on it actually
 Bear
Stoner - did the call them Kingley fittings? Still got the old tools lurking somewhere in my garage. Never used them though!
Posted : 22/03/2012 11:52 pm
A long brush looks more useful than a long stand
Posted : 22/03/2012 11:55 pm
Tried and tested flux applicator
Posted : 22/03/2012 11:57 pm
teacher didnt say, but having looked for "kingley" and found this
http://www.theplumbersmerchants.com/securex-fittings.asp
then yes, that looks like it. Teacher had a drift swager made up so I could anneal the tube and then flare it to match the olive.
Posted : 22/03/2012 11:58 pm
my t-shirt has some very funky colours on it from wiping my "applicator" off on it 😯
 Bear
Paul - if you put flux on with that then I'd sack you. Have you seen what it can do to your skin?
Posted : 22/03/2012 11:59 pm
tastes foul too
Posted : 23/03/2012 12:04 am
 Bear
hurts when it goes in you eye....
Posted : 23/03/2012 12:05 am
Bear - Member
It turned my overalls from blue to a red colour when I was 16. It stung like **** too. I learned quickly not to do it 🙂
Posted : 23/03/2012 12:12 am
what's in flux anyway?
Posted : 23/03/2012 12:15 am
Lift it off and rest it on some blocks, stop faffing and get it done.
Posted : 23/03/2012 12:21 am
