Hi all, appreciate these are stupid questions but have never built a mtb before. I am building an SS on an inbred slot dropout frame. First off, how should I route the front brake cable should it go from the back of the forks up the front to the bar with a zip tie on the forks?????
Second I cannot for the life of me get the rear caliper aligned it just keeps touching the pads. I do not know if this is because I have it in the wrong place on the IS mounts (as they are kind of slots rather than just holes – crap desciption!), or is it because it is a slot drop out it is more tricky?!
Any advice welcome (oh and the brakes are avid juicy 3s) – would pics help?
I would route the front brake the cleanest line possible (and minimise cable rub) It does not really matter where it goes as long as it does not rub on the tyre.
I imagine the rear brake is more tricky because of the slot drop-outs. Check that the caliper/pads are clearing the end of the disk first…
Always run the front hose up the inside of the forks up to the bridge using a couple of zip ties. If you have it on the outside there is a high risk that it will be damaged during fall offs or even get snagged on passing rocks and branches, which will cause you to fall off too!!
themyers – difficult to see if you have “dimples” in the bridge of your forks to guide the hose, like on my SIDs
Personally I went for this routing [sorry, not a great pic] using a single tie because it seemed the smoothest line: IMG_6336 by oxym0r0n, on Flickr
I have never had a problem with it being
As for rear – follw TomThumbs instructions to get caliper aligned with rear wheel (bolts attached to frame)
Then, push your calpiers apart, loosen the caliper bolts slightly – pump the brake lever a couple of times, then hold it on while you (or someone else!!) tightens the caliper bolts.
Hope that helps?
Posted 13 years ago
Viewing 6 posts - 1 through 6 (of 6 total)
The topic ‘Newbie building difficulties’ is closed to new replies.
