New Years Resolutio...
[Closed] New Years Resolution - Dedicated Single Speed - Now which one?
[#1146027]
Evening Folks,
Been debating for ages about changing one of my rides over to use as a 69er SS but after more deliberation/indecisiveness I am going to go dedicated SS for 2010 🙄
The plan is rigid but the rest is yet TBD.
So then any recommendations - open to all suggestions.......
26''/29''
Off the shelf or custom build.
Quite like the Singular Swift but read the frame is heavy?
So then.....what be your thoughts??
Cheers,
Mark
(pics are much appreciated 🙂 )
Posted : 20/12/2009 7:28 pm
Not a swift...
But have to say, I'm very, very, very tempted...
http://www.singularcycles.com/gryphon.html
Posted : 20/12/2009 7:30 pm
Being dim here......
Based entirely on the pictures isn't it a Swift with drops?
Posted : 20/12/2009 7:35 pm
 gee
29" - It suits SS really well as it rolls over things a lot better than 26".
Why not try a scandal - cheap and cheerful - and buy a nicer one if you like it? If you do like it, have a look at a Salsa Selma.
GB
Posted : 20/12/2009 7:37 pm
letmetalktomark - Member
...Quite like the Singular Swift but read the frame is heavy?
It's heavier than a Scandal, but when you build up a bike the frame weight is just a proportion of the overall weight. The handling makes up for it 🙂
Also the fork is very good, but you could save some weight by replacing it with a carbon one which will save you about 250 gms at a cost of £125, but you could recover some of the cost by eBaying the Singular fork.
BTW the Gryphon is like a Swift but with geometry for a non suspension fork. The Swift geometry allows for those people who may wish to put a heavy soggy maintenance-requiring vibration absorber on the front 🙂
Posted : 20/12/2009 7:41 pm
If you're going 29er then have a look a [url= http://www.ninerbikes.com/fly.aspx?layout=bike ]Niner Bikes[/url], either the One 9 or S.I.R 9 for SS, or carbon if you can afford it!
Posted : 20/12/2009 7:54 pm
And a shorter top tube a allow for the extra reach of a dropbar.
The Gryphos ride very well indeed.
Posted : 20/12/2009 8:04 pm
Cool.
Like the look of the 853 framed Niner but possibly at this stage beyond my budget 🙁
Are there many Swift riders on here?
Posted : 20/12/2009 8:06 pm
Cotic Simple with a carbon fork up front
Posted : 20/12/2009 8:07 pm
Oh forgot to say would prefer steel.
voodoooooo wanga 😀
Posted : 20/12/2009 8:20 pm
 Sam
Swifts are not that heavy, around 5lbs for the frame depending on size. As above, that's less than a quarter of your overall build weight (Steve Webb was 2nd solo at dusk til dawn on a Swift frame). There are a number of Swift riders on here, a search should turn up a number of them.
Posted : 20/12/2009 9:08 pm
Sanderson soloist or Genesis io cos you won't have cable stops or any means of attaching a mech hanger therefore you have to go expensive hub gears if you change your mind. (and then you won't!).
Posted : 20/12/2009 9:10 pm
 JRTG
if you can find one of these yu are in for a treat!
Posted : 20/12/2009 11:35 pm
 AJ
your not ruling out custom, but a niner is out of your budget? what yo bin on the loopy juice?
Posted : 21/12/2009 12:03 am
walla24 - Member
voodoooooo wanga
Nice bike, but watch out for cracking at the front of the chainstays.
Posted : 21/12/2009 2:39 am
AJ - Member
No loopy juice....yet.
Just meant either buying a complete bike or a frame and fork and building up to my own spec.
Posted : 21/12/2009 11:13 am
