never buy park tool...
[Closed] never buy park tools cable cutters
[#2902338]
they dont work..
Posted : 30/06/2011 1:02 pm
I have some and they work fine.
Posted : 30/06/2011 1:03 pm
Mine have been going strong for 6 years
 bigG
Yes they do, mine have worked faultlessly for some years. Is it possibly user error?
Posted : 30/06/2011 1:04 pm
A good set of sharp pliers also suffice.
Love mine too.
Just bought some, but as the Park's site indicates, cutters not always get a perfect cut, and to use file to sand cut end down, or something. Certainly better than any other bodge method i've tried.
Posted : 30/06/2011 1:05 pm
Mine are superb and I know a great many LBS spanner monkeys who will only use Park cutters.
Operator error, perhaps? 😉
Posted : 30/06/2011 1:07 pm
Got a ten year old set here. Still cutting fine.
10 - 15years on mine. If you get a little crushing when you cut the housing, pock some old inner through before and this acts to stop it. If you think any jaw type cutter will give a perfect end result that you need do absolutely no post cut finishing, I think you may be disappointed. I've heard Dremel type tools give good results.
Posted : 30/06/2011 1:08 pm
Mine work fine.
Perhaps you're a bit weak wristed..
Bought mine just before moving out of my parents so that makes them 10ish years old. Still perfect.
I'm sure they do work
TBH though, I'd never buy generic tools from Park, the quality is mediocre with a mid-range price point
If you really want good rope cutters, try Felco
I have two sets of Park cable cutters and they are of different types - one is much more substantial than the other.
So maybe you have a weedy pair?
Posted : 30/06/2011 1:09 pm
Agreed, but for specialist bike tools I can't really see why I would buy from anyone else.
Posted : 30/06/2011 1:11 pm
[i]but as the Park's site indicates, cutters not always get a perfect cut[/i]
So why pay £30 then? When you can get some that cut like that for £15?
Posted : 30/06/2011 1:13 pm
absolutely - cable cutters aren't specialist cycle tools though, they're just standard rope cutters
I've a halfords top cutter (~12" handle version) slices through inners and outers like butter, probaly overkill but I've not used normal piers/cutters since buying them.
Posted : 30/06/2011 1:15 pm
I have to say I think Park are overpriced and over-rated.
Campag way better for BB thread chasers etc.
Posted : 30/06/2011 1:17 pm
Real men use a rotary tool.
Posted : 30/06/2011 1:21 pm
 JonR
I use an axe, works for me.
Posted : 30/06/2011 1:23 pm
Is this some kind of reverse marketing ploy?
Post a negative comment so that loads of people are forced to step in. Clever.
Posted : 30/06/2011 1:24 pm
well im gona try go to a hardware shop and look there instead because the ones i have worked fine and now ive just bought some new cables they are bending and tearing my new ones to bits so ill get something that will defo cut them cables, ****ing bikes piss me off
Posted : 30/06/2011 1:29 pm
Couldn't cut clarkes outer cable with mine. No matter how hard you squeezed it just won't cut it. Go through shiumano stuff no probs though.
Posted : 30/06/2011 1:33 pm
Wimps.
I can cut them with my teeth.
Never owned some so cant comment, but I'm yet to find anything that will chop cable outer tidily. I usually dress them with an angle grinder.
Posted : 30/06/2011 1:36 pm
yeh well its not ya top make cable im using i just bought it from my lbs cheap, it looks the same as what i had so i don't see why it wont cut through the bugger
Posted : 30/06/2011 1:42 pm
They work fine most of the time but they do come with a good (lifetime?) warranty if they don't. My current set are a warranty replacement for my first because the clasp that holds them together broke.
Posted : 30/06/2011 1:46 pm
Ive got some that cut like scissor blades (ie. shearing rather than cutting edges meeting) and they have been cr@p since I was given them 15yrs ago, never worked and they languish in my tool box untouched. Wont even cut inners cleanly.
These, the CN2
I always use some no-name side cutting pliers
ie like this
which cut inner and outers cleanly first time every time.
Posted : 30/06/2011 3:10 pm
Eh - I have had mine for about 6 years now and still going strong - The only think is the grip/handle glue does give way so had to re0glue them on but apart form that they are fab 🙂
As above just warranty them - PT have a fab warranty replacement !
Posted : 30/06/2011 3:12 pm
 sv
Rolson ones from eBay for me.
Posted : 30/06/2011 3:14 pm
You guys that are having trouble using their Park [or any other cable cutters]
You have taken up any play that's occurred in the pivot via the nut - haven't you?
Posted : 30/06/2011 3:15 pm
i know many a great shop mechanic that swears AT park cutters ... worst of a bad bunch imho
Felco are amaizing but are or were - 60-80 quid a pair ....
shimano make good disposable ones - 8 - 12 months half hourly use day in day out
for home use i have a pair of bnq paralel linkage sidecutters - slices like butter 😀 - and you can sharpen them easy unlike the rope cutters which when sharpened have too big a gap and leave you cursing at your cables !
Posted : 30/06/2011 3:23 pm
My Park cutters have been faultless
Bad workman, tools, etc...
Posted : 30/06/2011 3:36 pm
Felco C7 - knocks all other wire cutters into a cocked hat!
8 years and still good.
Posted : 30/06/2011 4:13 pm
Mine are about 6 years old and are great love using them cut clean every time.
Posted : 30/06/2011 4:18 pm
 jeff
Thumbs down for Park cutters here - mine have been duff since I got given them.
If I'd bought them myself they'd have gone back.
Posted : 30/06/2011 4:23 pm
I don't like the Park Cutters either, for some reason I must have wimmens hands as it seems you need to have the hands of a neanderthal to open and grip them quickly and easily!
When I worked with bikes nearly full time, I bought a set of Japanese cutters they are much smaller neater and have never let me down.
Posted : 30/06/2011 4:26 pm
Felco here too. Top stuff
Posted : 30/06/2011 4:32 pm
uplink- no play in mine, they havent worked from new.
mike p-not sure how you can blame a workman, cant quite see how its possible to use them incorrectly? Shearing rather than parallel/side cutting is an inferior way to try cut something, which is why I am seemingly capable of using cheap pliers correctly using the same technique (push two handles together with one hand?) to cleanly cut cables.
jeff +1, I didnt pay for mine so have no receipt or investment to defend or beef against, they just dont work (my pair at any rate).
Posted : 30/06/2011 5:19 pm
10+ years on a set here. Never had an issue.
If you are struggling then a good swing of a nice sharp axe seems a suitable way of completing the task and easing the apparant frustration.
Posted : 30/06/2011 5:23 pm
 jonb
I found that for getting a clean cut on inner cables you get really good results if you heat up the cable with a lighter first. Even blunt pliers work then.
Posted : 30/06/2011 5:41 pm
can anyone link me for a cheap decent pair that will do the job?
Posted : 30/06/2011 8:56 pm
Mine worked OK for the first couple of bikes but went blunt ridiculously fast. Still cuts the cable, just frays the **** out of them. The cable-end crimper is nice though. Very poor, wouldn't have been worth £10.
So now I use these:
http://cgi.ebay.co.uk/7-Cable-Wire-Cutter-Copper-Pliers-Stripper-Ratchet-2271-/380351042283?pt=UK_BOI_Metalworking_Milling_Welding_Metalworking_Supplies_ET&hash=item588eb052eb
Though I only paid £4. Far better than Park, cuts just as well on day one, still going strong after 10 times the use that knackered the Parks, and a fraction of the price. You can buy these labelled up as bike-specific if you insist.
Posted : 30/06/2011 10:02 pm
You're suggesting we should steal them? Rent them? Borrow them? ❓
Posted : 30/06/2011 10:11 pm
